[AG-TECH] Multi-channel video capture
Fred Dech
fdech at uchicago.edu
Fri Mar 5 17:19:40 CST 2004
howdy.
i just installed AG2.1.2 on a
'WIN XP one-machine full node (inSORS Cube)' and after i've gone through
the process of adding the 4 VideoProductionServices i only end up with 4
outputs of 1 camera feed. it's consistently from the same camera. the
properties of the production services are:
Capture device: Videum Video Capture
Capture device: WnvVid32.dll 1_VideumAVX_VO_(PCI)
Capture device: WnvVid32.dll 2_VideumAVX_VO_(PCI)
Capture device: WnvVid32.dll 3_VideumAVX_VO_(PCI)
'anyone have a hint on what's going on here?
thanks.
--fred
Chris Osland wrote:
> Many thanks for that. I'm only used to AG1 at present, and no
> configuration is required - VIC just connects to all four streams
> (on the separate cards) and they are all set to Transmit by
> default. Maybe that doesn't work as easily in AG2.
> Cheers
> Chris
> ___________________________________________________________________
> Chris Osland Office tel: +44
> (0) 1235 446565
> Digital Media and Access Grid Medialab tel: +44 (0)
> 1235 446459
> BIT Department Access Grid room tel: +44
> (0) 1235 445666
> e-mail: C.D.Osland at rl.ac.uk Fax: +44
> (0) 1235 445597
> CLRC Rutherford Appleton Laboratory (Bldg. R18)
> Chilton, DIDCOT, Oxon OX11 0QX, UK
> [The contents of this email are confidential and are for the use of the
> intended recipient only.
> If you are not the intended recipient do not take any action on it or show
> it to anyone else,
> but return this email to the sender and delete your copy of it.]
> > -----Original Message-----
> > From: David Mcnabb [mailto:mcnabb at umd.edu]
> > Sent: 04 March 2004 14:59
> > To: C.D.Osland at rl.ac.uk
> > Cc: ag-tech at mcs.anl.gov
> > Subject: Re: [AG-TECH] Multi-channel video capture
> > On our WIN XP one-machine full nodes, the Winnov Videum 4400
> > has worked very well for us, though when we use it with the
> > AGv2 SW we get two video streams when only one camera is
> > attached. When used with the inSORS SW, the card works perfectly.
> > What do you mean by "extra work" when switching venues?
> > Under AGv2 I get a new vic each time I change venues, so I
> > must go in and turn on transmit as well as reset tiling to
> > triple (the default single tiling is rarely useful. Can I
> > change the defaults under AGv2 on XP?)
> > David McNabb
> > UMAGI
> > Univ. of Maryland
