[AG-TECH] First time setup problems [update]
Steven
s.jack at compserv.gla.ac.uk
Fri Mar 5 05:35:46 CST 2004
Hi Nigel AG2 seems to be working again.
You will find the link for the beacon software at http://ulcc.beacon.ja.net/
Note you want the java client and not the server.
Steven
Steven Jack
Computing Service
University of Glasgow
-----Original Message-----
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On Behalf
Of Nigel Cooke
Sent: 05 March 2004 09:38
To: ag-tech at mcs.anl.gov
Subject: Re: [AG-TECH] First time setup problems [update]
Hey all,
Firstly thanks to those who have already replied off the list - its
refreshing to see such quick and indepth support from the AG community. I
decided to downgrad to Version1 of the AG software as a number of the people
who replied said that they issues with V2 (especially as we dont have any
certificates as yet)
So at least now the software seems to be doing something - it fires up and I
can go into the venues website and it changes the room on the venue software
window. I can also see my own video window. So a few questions
- I have enabled multicast on the Cisco 2600 (ip multicast-routing) is this
all I need to do ?
- do I also need to enable multicast on the LAN switch Im plugged into as I
have downloaded an application that checks to see if the network is
multicast enabled - its saying no so Im guessing this is the LAN ?
- lastly does anyone have the becaon software
Once all of this is working how do you normally test the AccessGrid software
- I went into the test room but either I can't see anyone as no-one is
there, or its because of multicast.
Any help on this much appreciated.
thanks,
Nigel
Nigel Cooke wrote:
I am in the process of attempting to get AG up and running on a Windows2000
box - we recently got connected to the JANET network through an LES 100mb
circuit to Cambridge University. I have now downloaded and installed the
pre-required software and also the latest version of the AG toolkit. I then
go to start up the venue application (or indeed any other AG app) and it
thinks about it (egg-timer) and then nothing. If I load it up in debug mode
it flashes something up on the dos screen but its too quick to read.
Any points on this would be much appreciated.
regards,
Nigel
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040305/a3bb9316/attachment.htm>
