[AG-TECH] First time setup problems [update]
Nigel Cooke
ncooke at cambridge.oilfield.slb.com
Fri Mar 5 03:37:30 CST 2004
Hey all,
Firstly thanks to those who have already replied off the list - its
refreshing to see such quick and indepth support from the AG community.
I decided to downgrad to Version1 of the AG software as a number of the
people who replied said that they issues with V2 (especially as we dont
have any certificates as yet)
So at least now the software seems to be doing something - it fires up
and I can go into the venues website and it changes the room on the
venue software window. I can also see my own video window. So a few
questions
- I have enabled multicast on the Cisco 2600 (*ip multicast-routing)
*is this all I need to do ?
- do I also need to enable multicast on the LAN switch Im plugged into
as I have downloaded an application that checks to see if the network is
multicast enabled - its saying no so Im guessing this is the LAN ?
- lastly does anyone have the becaon software
Once all of this is working how do you normally test the AccessGrid
software - I went into the test room but either I can't see anyone as
no-one is there, or its because of multicast.
Any help on this much appreciated.
thanks,
Nigel
Nigel Cooke wrote:
> Hi,
> I am in the process of attempting to get AG up and running on a
> Windows2000 box - we recently got connected to the JANET network
> through an LES 100mb circuit to Cambridge University. I have now
> downloaded and installed the pre-required software and also the latest
> version of the AG toolkit. I then go to start up the venue application
> (or indeed any other AG app) and it thinks about it (egg-timer) and
> then nothing. If I load it up in debug mode it flashes something up on
> the dos screen but its too quick to read.
> Any points on this would be much appreciated.
> regards,
> Nigel
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040305/5d16a869/attachment.htm>
