[AG-TECH] First time setup problems [update]
Colin Byelong
c.byelong at ucl.ac.uk
Fri Mar 5 06:12:09 CST 2004
Hi Nigel,
You will need to configure more than ip multicast-routing for this to work,
Do you know if you will be running PIM in dense mode or sparse mode ?
either way you will need to configure PIM on your LES link and on your LAN
interface.
As you connect to Cambridge will you be part of there PIM domain if so your
router will need to know where the Cambridge rendezvous point is.
This can be configured or you can run Auto-rp,
Most of the information can be found at:
http://www.cisco.com/pcgi-bin/Support/browse/psp_view.pl?p=Technologies:Multicast
cheers
Colin
At 09:37 3/5/2004 +0000, Nigel Cooke wrote:
>Hey all,
>Firstly thanks to those who have already replied off the list - its
>refreshing to see such quick and indepth support from the AG community. I
>decided to downgrad to Version1 of the AG software as a number of the
>people who replied said that they issues with V2 (especially as we dont
>have any certificates as yet)
>So at least now the software seems to be doing something - it fires up and
>I can go into the venues website and it changes the room on the venue
>software window. I can also see my own video window. So a few questions
> - I have enabled multicast on the Cisco 2600 (ip multicast-routing) is
> this all I need to do ?
>- do I also need to enable multicast on the LAN switch Im plugged into as
>I have downloaded an application that checks to see if the network is
>multicast enabled - its saying no so Im guessing this is the LAN ?
>- lastly does anyone have the becaon software
>Once all of this is working how do you normally test the AccessGrid
>software - I went into the test room but either I can't see anyone as
>no-one is there, or its because of multicast.
>Any help on this much appreciated.
>thanks,
>Nigel
>Nigel Cooke wrote:
>>Hi,
>>I am in the process of attempting to get AG up and running on a
>>Windows2000 box - we recently got connected to the JANET network through
>>an LES 100mb circuit to Cambridge University. I have now downloaded and
>>installed the pre-required software and also the latest version of the AG
>>toolkit. I then go to start up the venue application (or indeed any other
>>AG app) and it thinks about it (egg-timer) and then nothing. If I load it
>>up in debug mode it flashes something up on the dos screen but its too
>>quick to read.
>>Any points on this would be much appreciated.
>>regards,
>>Nigel
