[AG-TECH] [BUG] Freeze when leaving a room
Joseph
joseph at cs.usyd.edu.au
Sun Jun 27 20:53:38 CDT 2004
Hi
I've some trouble with my AG2.2. Let me first describe exactly the way it
happens :
I launch AG2.2 using : VenueClient.py -d --personalNode .
When it starts, I enter the Asia Pacific Access Grid Lobby, then I enter a
room (the test room for example). When I enter this room there is no
trouble : VIC and RAT are closed and then opened again. But, when I want
to leave this room, VIC and RAT are closed and then most of the time my
VenueClient freezes.
To be sure the freezes are permanent I have let the VenueClient working
for a long time (more than 10 minutes) a few times.
In fact, the error seems to be :
06/28/04 11:31:31 1474570 EventClient EventClient.py:279 ERROR
Attempting to send on a disconnected EventClient
06/28/04 11:31:31 1474570 VenueClient VenueClient.py:358 ERROR
Heartbeat: Heartbeat exception is caught.
Traceback (most recent call last):
File "/usr/lib/python2.3/site-packages/AccessGrid/VenueClient.py", line
356, in __Heartbeat
self.privateId))
File "/usr/lib/python2.3/site-packages/AccessGrid/EventClient.py", line
280, in Send
raise EventClientWriteDataException
These lines appear each time before the freeze.
I've looked in the code but I don't have, for the time, a lot of ideas on
how to solve this error.
Do you have any clue ?
Thanks
Joseph
ps : I copy here the debug output around the errors lines above and until
the freeze :
06/28/04 11:31:29 16384 VenueClient VenueClient.py:920 INFO ExitVenue
06/28/04 11:31:29 16384 VenueClient VenueClient.py:950 INFO
ExitVenue: Stopping event client
06/28/04 11:31:29 16384 VenueClient VenueClient.py:954 DEBUG
ExitVenue: Send client exiting event
06/28/04 11:31:29 557068 EventClient EventClient.py:183 DEBUG Got read
handle=_38337908_p_globus_io_handle_t result=(722, 'an end-of-file was
reached') n=0
06/28/04 11:31:29 557068 EventClient EventClient.py:186 DEBUG
readCallback gets failure in result: 722 an end-of-file was reached
06/28/04 11:31:29 16384 VenueClient VenueClient.py:968 INFO
ExitVenue: Stopping node services
06/28/04 11:31:29 1540109 NodeService AGNodeService.py:287 INFO
NodeService.StopServices
06/28/04 11:31:29 1556494 ServiceManager AGServiceManager.py:408 INFO
AGServiceManager.StopServices
06/28/04 11:31:30 1572877 NodeService AGNodeService.py:311 INFO
NodeService.SetStreams
06/28/04 11:31:30 1572877 NodeService AGNodeService.py:242 INFO
NodeService.GetServices
06/28/04 11:31:31 1589262 ServiceManager AGServiceManager.py:400 INFO
AGServiceManager.GetServices
06/28/04 11:31:31 1572877 NodeService AGNodeService.py:716 INFO
NodeService.__SendStreamsToService
356, in __Heartbeat
self.privateId))
280, in Send
06/28/04 11:31:31 1474570 VenueClient VenueClient.py:372 INFO Try to
reconnect to venue
06/28/04 11:31:31 1474570 VenueClient VenueClient.py:883 INFO
ExitVenue: Stopping heartbeats
06/28/04 11:31:31 1474570 VenueClient VenueClient.py:888 DEBUG
ExitVenue: Stop event client obj
06/28/04 11:31:31 1474570 EventClient EventClient.py:301 DEBUG Cancel
pending callbacks
06/28/04 11:31:31 1474570 EventClient EventClient.py:307 DEBUG Free
callback _10016c08_p_callbackStruct
06/28/04 11:31:31 1474570 EventClient EventClient.py:313 DEBUG
EventClient.Stop: closing socket
06/28/04 11:31:31 1474570 EventClient EventClient.py:321 DEBUG
EventClient.Stop: closing queue
06/28/04 11:31:31 1474570 VenueClient VenueClient.py:890 DEBUG
ExitVenue: Remove event client reference
06/28/04 11:31:31 1474570 VenueClient VenueClient.py:895 INFO
ExitVenue: Stopping text client
06/28/04 11:31:31 1474570 VenueClient VenueClient.py:899 DEBUG
ExitVenue: Sending client disconnect event.
06/28/04 11:31:31 1474570 TextConnection TextClient.py:164 DEBUG
TextConnection.Write: EVENT --- Input
06/28/04 11:31:31 1474570 TextConnection TextClient.py:165 DEBUG
TextConnection.Write: Event:
Type: Disconnect Venue: 000000f7ad22d54c0081004e009d00a8421 Data:
000000fd68e036af0081004e009d00a8fd7
06/28/04 11:31:31 16386 TextConnection TextClient.py:207 DEBUG
TextConnection: Got read handle=_202f7d08_p_globus_io_handle_t ret=(756,
'an I/O operation was cancelled') n=0
06/28/04 11:31:31 16386 TextConnection TextClient.py:210 DEBUG
TextConnection: asynch read gets n=0, EOF
06/28/04 11:31:31 1474570 TextConnection TextClient.py:154 DEBUG
TextClient.Stop
06/28/04 11:31:31 1474570 VenueClient VenueClient.py:902 DEBUG
ExitVenue: Remove text client reference
06/28/04 11:31:31 1474570 VenueClient VenueClient.py:686 DEBUG
EnterVenue: Invoke venue enter
06/28/04 11:31:31 16384 VenueClient VenueClient.py:883 INFO
06/28/04 11:31:32 1474570 EventClient EventClient.py:166 DEBUG Have
callback handle _58a07208_p_callbackStruct
06/28/04 11:31:32 1474570 TextConnection TextClient.py:145 DEBUG
TextConnection: register returns _10077e08_p_callbackStruct
06/28/04 11:31:32 1474570 TextConnection TextClient.py:147 DEBUG
host:venues2.vislab.usyd.edu.au
port:8004
attr:<pyGlobus.io.TCPIOAttr instance at 0x41a8e16c>
06/28/04 11:31:32 1474570 TextConnection TextClient.py:149 DEBUG
socket:<pyGlobus.io.GSITCPSocket instance at 0x41a8e44c>
06/28/04 11:31:32 1474570 TextConnection TextClient.py:164 DEBUG
06/28/04 11:31:32 1474570 TextConnection TextClient.py:165 DEBUG
Type: Connect Venue: 000000f7ad22d54c0081004e009d00a8421 Data:
000000fd68e0d86a0081004e009d00a81b9
06/28/04 11:31:32 1474570 VenueClient VenueClient.py:752 DEBUG Setting
isInVenue flag.
