[AG-TECH] shared browser
    Benedikt Bjarni Bogason
    benedib at hi.is
    Fri Jun 18 12:00:52 CDT 2004
can it be because the server is running 2.1.2?
>    I tried this and I still cannot open any shared apps in 2.2?
> George
> At 09:15 AM 6/18/2004 -0500, Susanne Lefvert wrote:
>>The 2.2 shared browser should work. Have you been able to open any shared
>>application with 2.2 or is it just the shared browser that is giving you
>>trouble?  If you have problems with all your shared applications you
>> might
>>have a corrupt application database. You can solve that by renaming
>>C:\Documents and Settings\<username>\Application
>> Data\AccessGrid\Config\Application Database
>>and install the AGTK2.2 again. (Bug 962 in bugzilla).
>>Regards,
>>Susanne
>>On Fri, 18 Jun 2004, Benedikt Bjarni Bogason wrote:
>>> Hello
>>> I was trying to use the shared browser for the first time, between my
>>> node
>>> and a node in China. I was using AG 2.1.2 and multicasting, but the
>>> node
>>> in China was using AG 2.2 and was unicasting (or perhaps multicasting,
>>> I
>>> am not quite sure).
>>> I could add a browser and open it and start browsing, but the node in
>>> China was unable to open the browser. When they right-clicked on it and
>>> selected open, nothing happened.
>>> I also have version 2.2 on my node, so I switched to that, but then I
>>> ran
>>> into same difficulties as the node in china, nothing happened when i
>>> tried
>>> So we both switched to 2.1.2, and he switched computers and we both
>>> tried
>>> multicasting, that had the effect I could not hear nor see him (and
>>> vice
>>> versa) but the shared browser worked like a dream.
>>> Is this a known software issue with the 2.2 version, or is this perhaps
>>> a
>>> multicast problem? Anyone seen this problem before?
>>> Best regards,
>>> Benedikt Bogason
>>> benedikt.bogasson at bt.com
