[AG-TECH] shared browser
    Susanne Lefvert
    lefvert at mcs.anl.gov
    Fri Jun 18 12:47:56 CDT 2004
Ok, I have been able to reproduce this error. Apparently, when installing
2.2, the old SharedApplications directory and ApplicationDatabase file
remains from 2.1.2 and causes problems.  If solved this by renaming
C:\Documents and Settings\<username>\Application
Data\AccessGrid\Config\ApplicationDatabase
as well as
>C:\Documents and
Settings\<username>\Application>Data\AccessGrid\Config\SharedApplications
and then reinstalling the AGTk 2.2.
Please let me know if this solves your problems.
Susanne
On Fri, 18 Jun 2004, Benedikt Bjarni Bogason wrote:
> can it be because the server is running 2.1.2?
> >    I tried this and I still cannot open any shared apps in 2.2?
> > George
> > At 09:15 AM 6/18/2004 -0500, Susanne Lefvert wrote:
> >>The 2.2 shared browser should work. Have you been able to open any shared
> >>application with 2.2 or is it just the shared browser that is giving you
> >>trouble?  If you have problems with all your shared applications you
> >> might
> >>have a corrupt application database. You can solve that by renaming
> >> Data\AccessGrid\Config\Application Database
> >>and install the AGTK2.2 again. (Bug 962 in bugzilla).
> >>Regards,
> >>Susanne
> >>> Hello
> >>> I was trying to use the shared browser for the first time, between my
> >>> node
> >>> and a node in China. I was using AG 2.1.2 and multicasting, but the
> >>> node
> >>> in China was using AG 2.2 and was unicasting (or perhaps multicasting,
> >>> I
> >>> am not quite sure).
> >>> I could add a browser and open it and start browsing, but the node in
> >>> China was unable to open the browser. When they right-clicked on it and
> >>> selected open, nothing happened.
> >>> I also have version 2.2 on my node, so I switched to that, but then I
> >>> ran
> >>> into same difficulties as the node in china, nothing happened when i
> >>> tried
> >>> So we both switched to 2.1.2, and he switched computers and we both
> >>> tried
> >>> multicasting, that had the effect I could not hear nor see him (and
> >>> vice
> >>> versa) but the shared browser worked like a dream.
> >>> Is this a known software issue with the 2.2 version, or is this perhaps
> >>> a
> >>> multicast problem? Anyone seen this problem before?
> >>> Best regards,
> >>> Benedikt Bogason
> >>> benedikt.bogasson at bt.com
