[AG-TECH] shared browser
    George Estes
    gestes at ncsa.uiuc.edu
    Fri Jun 18 10:11:35 CDT 2004
   I tried this and I still cannot open any shared apps in 2.2?
George
At 09:15 AM 6/18/2004 -0500, Susanne Lefvert wrote:
>The 2.2 shared browser should work. Have you been able to open any shared
>application with 2.2 or is it just the shared browser that is giving you
>trouble?  If you have problems with all your shared applications you might
>have a corrupt application database. You can solve that by renaming
>C:\Documents and Settings\<username>\Application Data\AccessGrid\Config\Application Database
>and install the AGTK2.2 again. (Bug 962 in bugzilla).
>Regards,
>Susanne
>On Fri, 18 Jun 2004, Benedikt Bjarni Bogason wrote:
>> Hello
>> I was trying to use the shared browser for the first time, between my node
>> and a node in China. I was using AG 2.1.2 and multicasting, but the node
>> in China was using AG 2.2 and was unicasting (or perhaps multicasting, I
>> am not quite sure).
>> I could add a browser and open it and start browsing, but the node in
>> China was unable to open the browser. When they right-clicked on it and
>> selected open, nothing happened.
>> I also have version 2.2 on my node, so I switched to that, but then I ran
>> into same difficulties as the node in china, nothing happened when i tried
>> So we both switched to 2.1.2, and he switched computers and we both tried
>> multicasting, that had the effect I could not hear nor see him (and vice
>> versa) but the shared browser worked like a dream.
>> Is this a known software issue with the 2.2 version, or is this perhaps a
>> multicast problem? Anyone seen this problem before?
>> Best regards,
>> Benedikt Bogason
>> benedikt.bogasson at bt.com
