Fwd: Re: [AG-TECH] Fedora 2
Michael Miller
mimiller at ncsa.uiuc.edu
Wed Jun 16 19:54:14 CDT 2004
Doug,
I installed all the rpms listed and things began to work. But I ran into
this when importing a certificate:
[voyager at voyager ncsavs]$ VenueClient.py
bound to port 54652
bound to port 32971
Format
<AccessGrid.Security.wxgui.CertificateStatusBrowser.CertRequestWrapper i
nstance at 0xf64ac46c>
Set radio button to 1
path is servicecert.pem
Found valid cert, validKey= 0
Set radio button to True
(VenueClient.py:17971): Gtk-WARNING **: GtkEntry - did not receive
focus-out-eve
nt. If you
connect a handler to this signal, it must return
FALSE so the entry gets the event as well
Gtk-ERROR **: file gtkentry.c: line 4559 (blink_cb): assertion failed:
(GTK_WIDG
ET_HAS_FOCUS (entry))
aborting...
Aborted
Any ideas? Anyone?
I was able to request a service cert, so I'll see how that works when it
gets signed.
Michael Miller
NCSA
>X-Envelope-From: douglask at itee.uq.edu.au
>X-Envelope-To: <mimiller at ncsa.uiuc.edu>
>Subject: Re: [AG-TECH] Fedora 2
>From: Douglas Kosovic <douglask at itee.uq.edu.au>
>To: Michael Miller <mimiller at ncsa.uiuc.edu>
>X-Mailer: Ximian Evolution 1.4.6 (1.4.6-2)
>Date: Thu, 17 Jun 2004 10:12:28 +1000
>X-NCSA-MailScanner-Information: Please contact the help at ncsa.uiuc.edu for
>more information
>X-NCSA-MailScanner: Found to be clean
>X-Deliver-To: mimiller
>X-MD5SUM: cbf929c1b071432b2681c78b7ca67028
>X-Spam-Checker-Version: SpamAssassin 2.61 (1.212.2.1-2003-12-09-exp) on
> mail.ncsa.uiuc.edu
>X-Spam-Status: No, hits=-4.8 required=4.0 tests=BAYES_00,RCVD_IN_SORBS
> autolearn=no version=2.61
>X-Spam-Level:
>Hi Michael,
> > Should I install all the rpms at the link below?
>Apart from wxGTK-common-devel-2.4.2-0.fdr.1.3.i386.rpm which I didn't
>need to put up. Alternatively you could grab the following two:
>AccessGrid-2.2-Snapshot_20040616_224321.i386.rpm
>globus-accessgrid-2.4-1.i386.rpm
>and get the rest from elsewhere.
>I've been working with the AG developer to try and make sure that the
>AGtk2.2 builds on Fedora Core 2 and the changes get incorporated into
>CVS. I've been try to get the menus working in a portable fashion with
>Fedora Core 1, so haven't done much testing with Fedora Core 2 RPMs I
>put up, you might have more success with Sugree's RPMs.
>Cheers,
>Doug
> > At 06:31 PM 6/16/2004, you wrote:
> > > > If you want to try my build, you can download it via below link.
> http://osl.cpe.ku.ac.th/pub/accessgrid/fedora/linux/core/2/packages/AccessGrid-2.2-6.fc2.tar.gz
> > > > If you just want RPMS, check out below link.
> > > > http://osl.cpe.ku.ac.th/pub/accessgrid/fedora/linux/core/2/RPMS/
> > >Are the menus for you version working okay? Fortunately Gnome-2.6 which
> > >comes with Fedora Core 2 is able to handle legacy Gnome-1 menus (unlike
> > >FC1), except there is a problem with menu entries that use a URL, they
> > >don't work. e.g. for DevelopersDocumentation.desktop, the following 2
> > >lines:
> > >Exec=/usr/share/doc/Developer/index.html
> > >Type=URL
> > >had to be changed to:
> > >URL=file:///usr/share/doc/Developer/index.html
> > >Type=Link
> > >I don't know if RH7.3 is able to handle 'Type=Link' rather than
> > >'Type=URL'?
> > >I've also put up a RPMs, but it doesn't have the URL menu patches, here:
> > >http://www.itee.uq.edu.au/~agn/ag_fedora/FC2/stable/RPMS/
> > >Cheers,
> > >Doug
> > Thanx,
> > Michael Miller
> > System Engineer
> > Visualization Technology Support
> > Computing and Data Management
> > National Center for Supercomputing Applications
> > University of Illinois - UC
> > 217-649-0747
> > "If you're clear in your vision and trust the people in your team with
> > clear objectives, they will invariably do their best to achieve everything
> > desired, and usually deliver everything you could have hoped for and even
> > more." -Paul Debevec
Thanx,
Michael Miller
System Engineer
217-649-0747
