[AG-TECH] Fedora 2
    Douglas Kosovic
    douglask at itee.uq.edu.au
    Wed Jun 16 18:31:55 CDT 2004
Hi all,
On Thu, 2004-06-17 at 01:09, Sugree Phatanapherom wrote:
> > I've asked that the 'Requires' dependency on 'wxPythonGTK-py2.2' be
> > changed to 'wxPython' in the AccessGrid.spec.in file in CVS. With
> > this change, the wxPythonGTK-py2.2 package available on the RH7.3
> > AGtk 2.2 download page and wxPythonGTK2 from Fedora Extras will both
> > satisfy the 'wxPython' dependency.
> Umm. It seems I did wrong to change wxPythonGTK-py2.2 to wxPythonGTK-py2.3.
> > Unfortunately wxPythonGTK2 available from Fedora Extras (www.fedora.us)
> > doesn't work with GNOME 2.6, due to a bug with wxGTK2,  see:
> >     https://bugzilla.fedora.us/show_bug.cgi?id=1641
> > Fortunately, as the wxGTK 2.4.2 bug report states, in the interim there is
> > a version of wxGTK2 that works with Fedora Core 2 available at:
> >   http://resare.com/noa/rpms/fedora-2/
> I instead use wxGTK 2.4.0 from http://www.wxpython.org/ and
> wxPythonGTK-py2.3 2.4.2.4 from http://www.wxwindows.org/
I think wxGTK 2.4.0 from http://www.wxpython.org/ bypasses the GTK2
problem by linking with GTK 1.x rather than 2.x.
> > >          xawtv is needed by AccessGrid-2.2-6
> > xawtv no longer comes with Fedora Core 2, but you can install the version
> > from Fedora Core 1.
> I get xawtv 3.92 from dag repository at
> http://dag.wieers.com/packages/xawtv/xawtv-3.92-1.1.fc2.dag.i386.rpm.
> > >          libcrypto.so.2 is needed by AccessGrid-2.2-6
> > >          libssl.so.2 is needed by AccessGrid-2.2-6
> > I don't get that problem when built from source.
> Me too.
> > > Should I try the source? or do I need to install additional components?
> > You might want to wait till AccessGrid.spec.in is updated in CVS before
> > building from source. I think I could make an AGtk 2.2 RPM for Fedora Core
> 2
> > available in the interim (I need to get it from my home PC), till
> > AccessGrid.spec.in gets updated in CVS.
> I also have to modify gpt 3.0.1 due to misuse of $withval in configure. Umm.
> It might be old source. Anyway, it works properly right now.
There were some other minor patches needed for globus.spec and
AccessGrid.spec.in. The patches I used for globus.spec and
AccessGrid.spec.in are found in this file:
http://www.itee.uq.edu.au/~agn/ag_fedora/FC2/stable/patches/AG22fedora.patch
> If you want to try my build, you can download it via below link.
> http://osl.cpe.ku.ac.th/pub/accessgrid/fedora/linux/core/2/packages/AccessGrid-2.2-6.fc2.tar.gz
> If you just want RPMS, check out below link.
> http://osl.cpe.ku.ac.th/pub/accessgrid/fedora/linux/core/2/RPMS/
Are the menus for you version working okay? Fortunately Gnome-2.6 which
comes with Fedora Core 2 is able to handle legacy Gnome-1 menus (unlike
FC1), except there is a problem with menu entries that use a URL, they
don't work. e.g. for DevelopersDocumentation.desktop, the following 2
lines:
Exec=/usr/share/doc/Developer/index.html
Type=URL
had to be changed to:
URL=file:///usr/share/doc/Developer/index.html
Type=Link
I don't know if RH7.3 is able to handle 'Type=Link' rather than
'Type=URL'?
I've also put up a RPMs, but it doesn't have the URL menu patches, here:
http://www.itee.uq.edu.au/~agn/ag_fedora/FC2/stable/RPMS/
Cheers,
Doug
