[AG-TECH] Fedora 2
    Douglas Kosovic
    douglask at itee.uq.edu.au
    Wed Jun 16 23:40:43 CDT 2004
Hi Michael,
> I installed all the rpms listed and things began to work.  But I ran into
> this when importing a certificate:
> (VenueClient.py:17971): Gtk-WARNING **: GtkEntry - did not receive
> focus-out-event. If you
> connect a handler to this signal, it must return
> FALSE so the entry gets the event as well
> Gtk-ERROR **: file gtkentry.c: line 4559 (blink_cb): assertion failed:
> (GTK_WIDGET_HAS_FOCUS (entry))
> aborting...
> Aborted
> Any ideas?  Anyone?
I believe the problem occurs earlier in the stack trace (in particular
AccessGrid/Security/CertificateManager.py) and has been fixed in CVS. I
built the AccessGrid RPM from the AGTk 2.2 source code (with the patch I
posted previously) instead of building from a CVS snapshot.
You might be better off using Sugree Phatanapherom's Fedora Core 2 RPMs. I
want to get back a looking into a robust & portable way of adding toplevel
GNOME menus to to Fedora Core 1. Unlike FC2, FC1 isn't able to handle the
legacy Gnome-1 menus.
Cheers,
Doug
> >X-Envelope-From: douglask at itee.uq.edu.au
> >X-Envelope-To: <mimiller at ncsa.uiuc.edu>
> >Subject: Re: [AG-TECH] Fedora 2
> >From: Douglas Kosovic <douglask at itee.uq.edu.au>
> >To: Michael Miller <mimiller at ncsa.uiuc.edu>
> >X-Mailer: Ximian Evolution 1.4.6 (1.4.6-2)
> >Date: Thu, 17 Jun 2004 10:12:28 +1000
> >X-NCSA-MailScanner-Information: Please contact the help at ncsa.uiuc.edu for
> >more information
> >X-NCSA-MailScanner: Found to be clean
> >X-Deliver-To: mimiller
> >X-MD5SUM: cbf929c1b071432b2681c78b7ca67028
> >X-Spam-Checker-Version: SpamAssassin 2.61 (1.212.2.1-2003-12-09-exp) on
> >         mail.ncsa.uiuc.edu
> >X-Spam-Status: No, hits=-4.8 required=4.0 tests=BAYES_00,RCVD_IN_SORBS
> >         autolearn=no version=2.61
> >X-Spam-Level:
> >Hi Michael,
> > > Should I install all the rpms at the link below?
> >Apart from wxGTK-common-devel-2.4.2-0.fdr.1.3.i386.rpm which I didn't
> >need to put up. Alternatively you could grab the following two:
> >AccessGrid-2.2-Snapshot_20040616_224321.i386.rpm
> >globus-accessgrid-2.4-1.i386.rpm
> >and get the rest from elsewhere.
> >I've been working with the AG developer to try and make sure that the
> >AGtk2.2 builds on Fedora Core 2 and the changes get incorporated into
> >CVS. I've been try to get the menus working in a portable fashion with
> >Fedora Core 1, so haven't done much testing with Fedora Core 2 RPMs I
> >put up, you might have more success with Sugree's RPMs.
> >Cheers,
> >Doug
> > > At 06:31 PM 6/16/2004, you wrote:
> > > > > If you want to try my build, you can download it via below link.
http://osl.cpe.ku.ac.th/pub/accessgrid/fedora/linux/core/2/packages/AccessGrid-2.2-6.fc2.tar.gz
> > > > > If you just want RPMS, check out below link.
> > > > > http://osl.cpe.ku.ac.th/pub/accessgrid/fedora/linux/core/2/RPMS/
> > > >Are the menus for you version working okay? Fortunately Gnome-2.6
which
> > > >comes with Fedora Core 2 is able to handle legacy Gnome-1 menus
(unlike
> > > >FC1), except there is a problem with menu entries that use a URL,
they
> > > >don't work. e.g. for DevelopersDocumentation.desktop, the following 2
> > > >lines:
> > > >Exec=/usr/share/doc/Developer/index.html
> > > >Type=URL
> > > >had to be changed to:
> > > >URL=file:///usr/share/doc/Developer/index.html
> > > >Type=Link
> > > >I don't know if RH7.3 is able to handle 'Type=Link' rather than
> > > >'Type=URL'?
> > > >I've also put up a RPMs, but it doesn't have the URL menu patches,
here:
> > > >http://www.itee.uq.edu.au/~agn/ag_fedora/FC2/stable/RPMS/
> > > >Cheers,
> > > >Doug
> > > Thanx,
> > > Michael Miller
> > > System Engineer
> > > Visualization Technology Support
> > > Computing and Data Management
> > > National Center for Supercomputing Applications
> > > University of Illinois - UC
> > > 217-649-0747
> > > "If you're clear in your vision and trust the people in your team with
> > > clear objectives, they will invariably do their best to achieve
everything
> > > desired, and usually deliver everything you could have hoped for and
even
> > > more." -Paul Debevec
> Thanx,
> Michael Miller
> System Engineer
> 217-649-0747
> clear objectives, they will invariably do their best to achieve everything
> desired, and usually deliver everything you could have hoped for and even
