[AG-TECH] AG2.2 video/audio problems
    Michael daley
    Mike.W.Daley at cs.cardiff.ac.uk
    Tue Jun 15 08:29:00 CDT 2004
Many thanks I'll try that now
Mike
Frank Sweetser wrote:
>On Tue, Jun 15, 2004 at 01:36:04PM +0100, Michael daley wrote:
>>I've just uninstalled AG2.1.2 which was working fine.
>>With AG2.2 installed I can connect but get no video or audio coming up.
>>Anyone with same problems or solutions.
>The local port used by the services changed when run under personalNode.
>Go to node management, add your service manager back as localhost on port
>11000, readd your services, save, and you should be all set.
>Also, make sure to delete the GLOBUS_HOSTNAME env setting as well, otherwise
>you'll have problems if your hostname or IP address ever change.
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040615/0ad36d70/attachment.htm>
