[AG-TECH] AG2.2 video/audio problems
    Michael daley
    Mike.W.Daley at cs.cardiff.ac.uk
    Wed Jun 16 03:33:05 CDT 2004
Got further with this. I now have the vic and rat windows. RAT works
fine. I can receive video but cannot transmit.
I have tried adding a video service and videoproducer but get an error
Service Manager couldn't retrieve service package
videoconsumer is added OK
Any suggestions
Thanks
 Mike
Frank Sweetser wrote:
>On Tue, Jun 15, 2004 at 01:36:04PM +0100, Michael daley wrote:
>>I've just uninstalled AG2.1.2 which was working fine.
>>With AG2.2 installed I can connect but get no video or audio coming up.
>>Anyone with same problems or solutions.
>The local port used by the services changed when run under personalNode.
>Go to node management, add your service manager back as localhost on port
>11000, readd your services, save, and you should be all set.
>Also, make sure to delete the GLOBUS_HOSTNAME env setting as well, otherwise
>you'll have problems if your hostname or IP address ever change.
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040616/19f60c44/attachment.htm>
