FW: [AG-TECH] Video Resource Config file?
    Sabihuddin, Siraj
    Siraj.Sabihuddin at nrc-cnrc.gc.ca
    Thu Jun 10 07:40:43 CDT 2004
One additional point to my previous mail (see below)....make sure that you
only have one video service added in the "Access Grid Node Management"
dialogue (each video service will start its own instance of VIC). You can
remove services by right clicking on the service and selecting "remove".
Siraj
Student Programmer
Information Security Group, Institute for Information Technology
National Research Council (NRC), Ottawa, Canada
Email: Siraj.Sabihuddin at nrc-cnrc.gc.ca
<mailto:Siraj.Sabihuddin at nrc-cnrc.gc.ca> ,
WWW - NRC: http://iit-iti.nrc-cnrc.gc.ca
-----Original Message-----
Sent: Thursday, June 10, 2004 8:36 AM
To: 'ARSC Grid Op's'
Subject: RE: [AG-TECH] Video Resource Config file?
The services are located in two places the first is in the AGtk 2.2
installation directory.  If you installed AGtk2.2 in the default directory
check:
"C:\Program Files\Access Grid Toolkit\NodeServices" (for 2.2 beta)
"C:\Program Files\AGtk2.2\NodeServices" (for 2.2 release)
The zip files in this directory are the ones that will show up in the AGtk
services dialogue (so in your case "VideoService.zip")....the file is
automatically decompressed by the AGtk2.2 software.  If you have two
identical services showing up it is likely that there are two zip files with
the same internal name - to check you can uncompress the zip files located
in the "NodeServices" directory and have a look at the names of the zipped
files; they should match the name of the zip file itself (i.e. for
"VideoService.zip", the files in the zip archive should be named:
"VideoService.svc", "VideoService.py" and "vic.exe").  In addition, opening
up "VideoService.svc" in a text editor, the name field should have the
value: "VideoService".  Make sure that no other .zip file in the
"NodeServices" directory has the name "VideoService" assigned to it at any
level (that is,  make sure that "VideoService" is not used as a file name
for the .zip file and its contents and that it is not used in the .svc file
under the name field).
Sometimes it is also necessary to remove files from the "C:\Documents and
Settings\<username>\Application Data\AccessGrid\local_services" directory
(where <username> should be replaced with your login name).  This directory
will contain the following (or something similar anyway..):
AudioService (directory)
VideoService (directory)
AudioService.py
AudioService.zip
VideoService.py
VideoService.zip
If the video service does not start up properly it may be because the copy
in the "local_services" directory is out dated.  Try deleting the related
files (i.e. VideoService (directory), VideoService.py, VideoService.zip) -
don't worry these files should be recreated automatically when you add the
service via the AGtk2.2 GUI
It is a little difficult to explain in text - so if you have any
difficulties let me know.
Siraj
Student Programmer
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On Behalf
Of ARSC Grid Op's
Sent: Wednesday, June 09, 2004 3:17 PM
To: ag-tech at mcs.anl.gov
Subject: [AG-TECH] Video Resource Config file?
Quick question, anyone know what file is being used when you add "Video
Service" and a resource listing appears. I am getting duplicates in the list
and the venue client is launching duplicate video streams. Is there some
config file that is associated with the video resources?
I am on a W2k machine with AGtk 2.2
Eric Peterson
Arctic Region Supercomputing Center
  _____
Do you Yahoo!?
Friends. Fun. Try the all-new Yahoo!  <http://messenger.yahoo.com/>
Messenger
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040610/bbf0aed8/attachment.htm>
