[AG-TECH] Upgrading to 2.2
    Ivan R. Judson
    judson at mcs.anl.gov
    Fri Jun  4 07:12:18 CDT 2004
The media executables (rat.exe, vic.exe, et al) are no longer installed in
the toolkit. These files are packaged within the node services that they
are required for. This change is needed so that node services can be
packaged and distributed in a clean and efficient manner.
The end result is you should not find vic and rat installed in some
location you can execute them from, they are unpacked and executed by the
venue client automatically --
--Ivan
On Wed, 2 Jun 2004, ARSC Grid Op's wrote:
> I as well have tried removing the GLOBUS_HOSTNAME variable with no luck. I think there might be something wrong with the installer. Because I am not getting rat.exe or vic.exe  files in the /bin dir of the install path. I also have the same screenshot of the service manager as Jennifer. I have tried reinstalling, restarting and re-downloading all the files including active python 2.3, wxpython and the 2.2 toolkit . I was able to get and run the older version of the toolkit (2.1.2) with python 2.2 with no problems. Also selecting exit from the Venue Client causes the program to hang everytime. I have to force quit the client through Task manager in order to kill the process.
> - Eric Peterson
> Jennifer Teig von Hoffman <jtvh at bu.edu> wrote:
> I seem to be having the same problem, and I've already removed the
> GLOBUS_HOSTNAME variable (as suggested earlier on this thread) and
> rebooted for good measure. When I open Node Manager (from the Venue
> Client), there doesn't appear to be a ServiceManager running. Here's a
> screen shot:
> http://scv.bu.edu/~jtvh/images/error.jpg
> BTW, I do find rat.exe on my hard drive, in AudioService.zip.
> - Jennifer
> Michael Miller wrote:
> > Eric,
> > Check the Node Config and make sure the ServiceManager for localhost is
> > on port 11000. This changed in the latest release.
> > Michael Miller
> > NCSA
> > At 02:43 PM 6/2/2004, ARSC Grid Op's wrote:
> >> Hello,
> >> I am currently trying to upgrade a Windows 2000 Machine to the new
> >> 2.2 Toolkit released yesterday. When I run the Venue Client Shortcut,
> >> the program launches, but Rat or Vic never lauch when a venue is
> >> selected. I searched for rat.exe and vic.exe and it is not present
> >> anywhere on the machine. I have tried reinstalling, but with the same
> >> results. Any ideas? Thanks.
> >> - Eric Peterson
> >> Arctic Region Supercomputing Center
> >> Fairbanks, Alaska
> >> Do you Yahoo!?
> >> Friends. Fun. Try the all-new Yahoo!
> >> Messenger
> > Thanx,
> > Michael Miller
> > System Engineer
> > Visualization Technology Support
> > Computing and Data Management
> > National Center for Supercomputing Applications
> > University of Illinois - UC
> > 217-649-0747
> > "If you're clear in your vision and trust the people in your team with
> > clear objectives, they will invariably do their best to achieve
> > everything desired, and usually deliver everything you could have hoped
> > for and even more." -Paul Debevec
> Do you Yahoo!?
> Friends.  Fun. Try the all-new Yahoo! Messenger
