[AG-TECH] Upgrading to 2.2
    Brian Corrie
    bcorrie at sfu.ca
    Thu Jun  3 23:25:13 CDT 2004
Hello all,
I found that removing AG 2.1.2 was not enough. I have not tried the new
release but with the beta I found that things did not work until I got
rid of the 2.1.2 AccessGrid folder in the Application Data folder for
each user. This is not removed by the 2.1.2 removal.
It seemed like it was picking up old configuration information as Tom
implies (the wrong port). Other odd things seemed to be happening as
well before I removed the AccessGrid folder (I couldn't save new configs
- actually I code save them but it would never load them or find them
again).
I removed 2.1.2, then renamed the AccessGrid folder, then did a 2.2
install. Everything then starts up correctly with the new Service
Manager and Node Manager on the correct ports with the default services
starting automatically... Remeber that your certs are in the AccessGrid
folder, so you will need to re-import them with 2.2. That is why you
should not delete the AccessGrid folder 8-)
Cheers,
Brian
Thomas D. Uram wrote:
> The problem with old node configurations is clear, and has to do with
> the service manager running on a different port.
> When the venue client runs (with the personal node option, which is the
> default from the menus), it starts the node service and service manager.
>  The service manager was in previous releases on port 12000; it is now
> on port 11000.  Old node configurations will look for the service
> manager on port 12000 and fail. If you rebuild the node configuration
> using a service manager on port 11000, everything should work fine.
> Deb:  If you were trying to create a new config using the old port, this
> should fix your problem as well.  If not, please forward more detail
> about the problem you're encountering.
> Thanks,
> Tom
> Deb Agarwal wrote:
>> I also get the error loading the default windows config or creating
>> my own manually on Windows XP.
>> Deb
>> Jennifer Teig von Hoffman wrote:
>>> Hmm, I just tried that, and I get errors when I try to load the
>>> defaultWindows config, or either of the other configs I'd created
>>> under 2.1.2b, which apparently were carried over to the new
>>> installation.
>>> - Jennifer
>>> ARSC Grid Op's wrote:
>>>> I got everything working now with Windows 2000 and the new ver. 2.2.
>>>> Seems the problem was the default config file "defaultWindows"
>>>> failed to load. Instead I manually added the local service manager
>>>> and services and that did the trick. Thanks again.
>>>> - Eric Peterson
>>>>             I seem to be having the same problem, and I've already
>>>> removed the
>>>>         GLOBUS_HOSTNAME variable (as suggested earlier on this
>>>> thread) and
>>>>         rebooted for good measure. When I open Node Manager (from
>>>> the Venue
>>>>         Client), there doesn't appear to be a ServiceManager running.
>>>>         Here's a
>>>>         screen shot:
>>>>         http://scv.bu.edu/~jtvh/images/error.jpg
>>>>         BTW, I do find rat.exe on my hard drive, in AudioService.zip.
>>>>         - Jennifer
>>>>         Michael Miller wrote:
>>>>          > Eric,
>>>>          > Check the Node Config and make sure the ServiceManager for
>>>>         localhost is
>>>>          > on port 11000. This changed in the latest release.
>>>>          > Michael Miller
>>>>          > NCSA
>>>>          > At 02:43 PM 6/2/2004, ARSC Grid Op's wrote:
>>>>          >> Hello,
>>>>          >> I am currently trying to upgrade a Windows 2000 Machine to
>>>>         the new
>>>>          >> 2.2 Toolkit released yesterday. W! ! hen I run the Venue
>>>>         Client Shortcut,
>>>>          >> the program launches, but Rat or Vic never lauch when a
>>>>         venue is
>>>>          >> selected. I searched for rat.exe and vic.exe and it is not
>>>>         present
>>>>          >> anywhere on the machine. I have tried reinstalling, but
>>>> with
>>>>         the same
>>>>          >> results. Any ideas? Thanks.
>>>>          >> - Eric Peterson
>>>>          >> Arctic Region Supercomputing Center
>>>>          >> Fairbanks, Alaska
>>>>          >> Do you Yahoo!?
>>>>          >> Friends. Fun. Try the all-new Yahoo!
>>>>          >> Messenger
>>>>          > Thanx,
>>>>          > Michael Miller
>>>>          > System Engineer
>>>>          > Visualization Technology Support
>>>>          > Computing and Data Management
>>>>          > National Center for Supercomputing Applications
>>>>          > University of Illinois - UC
>>>>          > 217-649-0747
>>>>          > "If you're clear in your vision and trust the people in your
>>>>         team with
>>>>          > clear objectives, they will! inv! ariably do their best to
>>>>         achieve
>>>>          > everything desired, and usually deliver everything you could
>>>>         have hoped
>>>>          > for and even more." -Paul Debevec
>>>>     Do you Yahoo!?
>>>>     Friends. Fun. Try the all-new Yahoo! Messenger
>>>>     <http://messenger.yahoo.com/>
>>>> Do you Yahoo!?
