[AG-TECH] Upgrading to 2.2
    Randy Groves
    randy.groves at boeing.com
    Fri Jun  4 18:47:18 CDT 2004
This means that I'll have to keep an extra rat.exe around.  I always use
the RAT with the -allow_loopback option to test my audio after an install
and before a session.   Unless there is a new service incorporated into the
venue now?
-randy
At 05:12 AM 6/4/2004, Ivan R. Judson wrote:
>The media executables (rat.exe, vic.exe, et al) are no longer installed in
>the toolkit. These files are packaged within the node services that they
>are required for. This change is needed so that node services can be
>packaged and distributed in a clean and efficient manner.
>The end result is you should not find vic and rat installed in some
>location you can execute them from, they are unpacked and executed by the
>venue client automatically --
>--Ivan
>On Wed, 2 Jun 2004, ARSC Grid Op's wrote:
> > I as well have tried removing the GLOBUS_HOSTNAME variable with no
> luck. I think there might be something wrong with the installer. Because
> I am not getting rat.exe or vic.exe  files in the /bin dir of the install
> path. I also have the same screenshot of the service manager as Jennifer.
> I have tried reinstalling, restarting and re-downloading all the files
> including active python 2.3, wxpython and the 2.2 toolkit . I was able to
> get and run the older version of the toolkit (2.1.2) with python 2.2 with
> no problems. Also selecting exit from the Venue Client causes the program
> to hang everytime. I have to force quit the client through Task manager
> in order to kill the process.
> > - Eric Peterson
> > Jennifer Teig von Hoffman <jtvh at bu.edu> wrote:
> > I seem to be having the same problem, and I've already removed the
> > GLOBUS_HOSTNAME variable (as suggested earlier on this thread) and
> > rebooted for good measure. When I open Node Manager (from the Venue
> > Client), there doesn't appear to be a ServiceManager running. Here's a
> > screen shot:
> > http://scv.bu.edu/~jtvh/images/error.jpg
> > BTW, I do find rat.exe on my hard drive, in AudioService.zip.
> > - Jennifer
> > Michael Miller wrote:
> > > Eric,
> > > Check the Node Config and make sure the ServiceManager for localhost is
> > > on port 11000. This changed in the latest release.
> > > Michael Miller
> > > NCSA
> > > At 02:43 PM 6/2/2004, ARSC Grid Op's wrote:
> > >> Hello,
> > >> I am currently trying to upgrade a Windows 2000 Machine to the new
> > >> 2.2 Toolkit released yesterday. When I run the Venue Client Shortcut,
> > >> the program launches, but Rat or Vic never lauch when a venue is
> > >> selected. I searched for rat.exe and vic.exe and it is not present
> > >> anywhere on the machine. I have tried reinstalling, but with the same
> > >> results. Any ideas? Thanks.
> > >> - Eric Peterson
> > >> Arctic Region Supercomputing Center
> > >> Fairbanks, Alaska
> > >> Do you Yahoo!?
> > >> Friends. Fun. Try the all-new Yahoo!
> > >> Messenger
> > > Thanx,
> > > Michael Miller
> > > System Engineer
> > > Visualization Technology Support
> > > Computing and Data Management
> > > National Center for Supercomputing Applications
> > > University of Illinois - UC
> > > 217-649-0747
> > > "If you're clear in your vision and trust the people in your team with
> > > clear objectives, they will invariably do their best to achieve
> > > everything desired, and usually deliver everything you could have hoped
> > > for and even more." -Paul Debevec
> > Do you Yahoo!?
> > Friends.  Fun. Try the all-new Yahoo! Messenger
