[AG-TECH] Upgrading to 2.2
    Thomas D. Uram
    turam at mcs.anl.gov
    Thu Jun  3 15:34:17 CDT 2004
The problem with old node configurations is clear, and has to do with
the service manager running on a different port.
When the venue client runs (with the personal node option, which is the
default from the menus), it starts the node service and service manager.
  The service manager was in previous releases on port 12000; it is now
on port 11000.  Old node configurations will look for the service
manager on port 12000 and fail. If you rebuild the node configuration
using a service manager on port 11000, everything should work fine.
Deb:  If you were trying to create a new config using the old port, this
should fix your problem as well.  If not, please forward more detail
about the problem you're encountering.
Tom
Deb Agarwal wrote:
> I also get the error loading the default windows config or creating
> my own manually on Windows XP.
> Deb
> Jennifer Teig von Hoffman wrote:
>> Hmm, I just tried that, and I get errors when I try to load the
>> defaultWindows config, or either of the other configs I'd created
>> under 2.1.2b, which apparently were carried over to the new installation.
>> - Jennifer
>> ARSC Grid Op's wrote:
>>> I got everything working now with Windows 2000 and the new ver. 2.2.
>>> Seems the problem was the default config file "defaultWindows" failed
>>> to load. Instead I manually added the local service manager and
>>> services and that did the trick. Thanks again.
>>> - Eric Peterson
>>>             I seem to be having the same problem, and I've already
>>> removed the
>>>         GLOBUS_HOSTNAME variable (as suggested earlier on this
>>> thread) and
>>>         rebooted for good measure. When I open Node Manager (from the
>>> Venue
>>>         Client), there doesn't appear to be a ServiceManager running.
>>>         Here's a
>>>         screen shot:
>>>         http://scv.bu.edu/~jtvh/images/error.jpg
>>>         BTW, I do find rat.exe on my hard drive, in AudioService.zip.
>>>         - Jennifer
>>>         Michael Miller wrote:
>>>          > Eric,
>>>          > Check the Node Config and make sure the ServiceManager for
>>>         localhost is
>>>          > on port 11000. This changed in the latest release.
>>>          > Michael Miller
>>>          > NCSA
>>>          > At 02:43 PM 6/2/2004, ARSC Grid Op's wrote:
>>>          >> Hello,
>>>          >> I am currently trying to upgrade a Windows 2000 Machine to
>>>         the new
>>>          >> 2.2 Toolkit released yesterday. W! ! hen I run the Venue
>>>         Client Shortcut,
>>>          >> the program launches, but Rat or Vic never lauch when a
>>>         venue is
>>>          >> selected. I searched for rat.exe and vic.exe and it is not
>>>         present
>>>          >> anywhere on the machine. I have tried reinstalling, but with
>>>         the same
>>>          >> results. Any ideas? Thanks.
>>>          >> - Eric Peterson
>>>          >> Arctic Region Supercomputing Center
>>>          >> Fairbanks, Alaska
>>>          >> Do you Yahoo!?
>>>          >> Friends. Fun. Try the all-new Yahoo!
>>>          >> Messenger
>>>          > Thanx,
>>>          > Michael Miller
>>>          > System Engineer
>>>          > Visualization Technology Support
>>>          > Computing and Data Management
>>>          > National Center for Supercomputing Applications
>>>          > University of Illinois - UC
>>>          > 217-649-0747
>>>          > "If you're clear in your vision and trust the people in your
>>>         team with
>>>          > clear objectives, they will! inv! ariably do their best to
>>>         achieve
>>>          > everything desired, and usually deliver everything you could
>>>         have hoped
>>>          > for and even more." -Paul Debevec
>>>     Do you Yahoo!?
>>>     Friends. Fun. Try the all-new Yahoo! Messenger
>>>     <http://messenger.yahoo.com/>
>>> Do you Yahoo!?
