[AG-TECH] Upgrading to 2.2
    Deb Agarwal
    DAAgarwal at lbl.gov
    Thu Jun  3 14:56:18 CDT 2004
I also get the error loading the default windows config or creating
my own manually on Windows XP.
Deb
Jennifer Teig von Hoffman wrote:
> Hmm, I just tried that, and I get errors when I try to load the
> defaultWindows config, or either of the other configs I'd created under
> 2.1.2b, which apparently were carried over to the new installation.
> - Jennifer
> ARSC Grid Op's wrote:
>> I got everything working now with Windows 2000 and the new ver. 2.2.
>> Seems the problem was the default config file "defaultWindows" failed
>> to load. Instead I manually added the local service manager and
>> services and that did the trick. Thanks again.
>> - Eric Peterson
>>         I seem to be having the same problem, and I've already removed
>> the
>>         GLOBUS_HOSTNAME variable (as suggested earlier on this thread)
>> and
>>         rebooted for good measure. When I open Node Manager (from the
>> Venue
>>         Client), there doesn't appear to be a ServiceManager running.
>>         Here's a
>>         screen shot:
>>         http://scv.bu.edu/~jtvh/images/error.jpg
>>         BTW, I do find rat.exe on my hard drive, in AudioService.zip.
>>         - Jennifer
>>         Michael Miller wrote:
>>          > Eric,
>>          > Check the Node Config and make sure the ServiceManager for
>>         localhost is
>>          > on port 11000. This changed in the latest release.
>>          > Michael Miller
>>          > NCSA
>>          > At 02:43 PM 6/2/2004, ARSC Grid Op's wrote:
>>          >> Hello,
>>          >> I am currently trying to upgrade a Windows 2000 Machine to
>>         the new
>>          >> 2.2 Toolkit released yesterday. W! ! hen I run the Venue
>>         Client Shortcut,
>>          >> the program launches, but Rat or Vic never lauch when a
>>         venue is
>>          >> selected. I searched for rat.exe and vic.exe and it is not
>>         present
>>          >> anywhere on the machine. I have tried reinstalling, but with
>>         the same
>>          >> results. Any ideas? Thanks.
>>          >> - Eric Peterson
>>          >> Arctic Region Supercomputing Center
>>          >> Fairbanks, Alaska
>>          >> Do you Yahoo!?
>>          >> Friends. Fun. Try the all-new Yahoo!
>>          >> Messenger
>>          > Thanx,
>>          > Michael Miller
>>          > System Engineer
>>          > Visualization Technology Support
>>          > Computing and Data Management
>>          > National Center for Supercomputing Applications
>>          > University of Illinois - UC
>>          > 217-649-0747
>>          > "If you're clear in your vision and trust the people in your
>>         team with
>>          > clear objectives, they will! inv! ariably do their best to
>>         achieve
>>          > everything desired, and usually deliver everything you could
>>         have hoped
>>          > for and even more." -Paul Debevec
>>     Do you Yahoo!?
>>     Friends. Fun. Try the all-new Yahoo! Messenger
>>     <http://messenger.yahoo.com/>
>> Do you Yahoo!?
Deb Agarwal                          e-mail:DAAgarwal at lbl.gov
MS50B-2239                           phone :(510)486-7078
Lawrence Berkeley National Lab       URL: http://www-itg.lbl.gov/~deba
Berkeley, CA 94720
