[AG-TECH] Upgrading to 2.2
    Jennifer Teig von Hoffman
    jtvh at bu.edu
    Thu Jun  3 16:17:48 CDT 2004
Thanks Tom!
Could you be a little more specific about how to rebuild the node
configuration using a service manager on port 11000? I've selected
"Service Manager," "Add" within the Node Management window, but I'm not
sure exactly what to enter in the Add Service Manager Dialog box.
- Jennifer
Thomas D. Uram wrote:
> The problem with old node configurations is clear, and has to do with
> the service manager running on a different port.
> When the venue client runs (with the personal node option, which is the
> default from the menus), it starts the node service and service manager.
>  The service manager was in previous releases on port 12000; it is now
> on port 11000.  Old node configurations will look for the service
> manager on port 12000 and fail. If you rebuild the node configuration
> using a service manager on port 11000, everything should work fine.
> Deb:  If you were trying to create a new config using the old port, this
> should fix your problem as well.  If not, please forward more detail
> about the problem you're encountering.
> Thanks,
> Tom
> Deb Agarwal wrote:
>> I also get the error loading the default windows config or creating
>> my own manually on Windows XP.
>> Deb
>> Jennifer Teig von Hoffman wrote:
>>> Hmm, I just tried that, and I get errors when I try to load the
>>> defaultWindows config, or either of the other configs I'd created
>>> under 2.1.2b, which apparently were carried over to the new
>>> installation.
>>> - Jennifer
>>> ARSC Grid Op's wrote:
>>>> I got everything working now with Windows 2000 and the new ver. 2.2.
>>>> Seems the problem was the default config file "defaultWindows"
>>>> failed to load. Instead I manually added the local service manager
>>>> and services and that did the trick. Thanks again.
>>>> - Eric Peterson
>>>>             I seem to be having the same problem, and I've already
>>>> removed the
>>>>         GLOBUS_HOSTNAME variable (as suggested earlier on this
>>>> thread) and
>>>>         rebooted for good measure. When I open Node Manager (from
>>>> the Venue
>>>>         Client), there doesn't appear to be a ServiceManager running.
>>>>         Here's a
>>>>         screen shot:
>>>>         http://scv.bu.edu/~jtvh/images/error.jpg
>>>>         BTW, I do find rat.exe on my hard drive, in AudioService.zip.
>>>>         - Jennifer
>>>>         Michael Miller wrote:
>>>>          > Eric,
>>>>          > Check the Node Config and make sure the ServiceManager for
>>>>         localhost is
>>>>          > on port 11000. This changed in the latest release.
>>>>          > Michael Miller
>>>>          > NCSA
>>>>          > At 02:43 PM 6/2/2004, ARSC Grid Op's wrote:
>>>>          >> Hello,
>>>>          >> I am currently trying to upgrade a Windows 2000 Machine to
>>>>         the new
>>>>          >> 2.2 Toolkit released yesterday. W! ! hen I run the Venue
>>>>         Client Shortcut,
>>>>          >> the program launches, but Rat or Vic never lauch when a
>>>>         venue is
>>>>          >> selected. I searched for rat.exe and vic.exe and it is not
>>>>         present
>>>>          >> anywhere on the machine. I have tried reinstalling, but
>>>> with
>>>>         the same
>>>>          >> results. Any ideas? Thanks.
>>>>          >> - Eric Peterson
>>>>          >> Arctic Region Supercomputing Center
>>>>          >> Fairbanks, Alaska
>>>>          >> Do you Yahoo!?
>>>>          >> Friends. Fun. Try the all-new Yahoo!
>>>>          >> Messenger
>>>>          > Thanx,
>>>>          > Michael Miller
>>>>          > System Engineer
>>>>          > Visualization Technology Support
>>>>          > Computing and Data Management
>>>>          > National Center for Supercomputing Applications
>>>>          > University of Illinois - UC
>>>>          > 217-649-0747
>>>>          > "If you're clear in your vision and trust the people in your
>>>>         team with
>>>>          > clear objectives, they will! inv! ariably do their best to
>>>>         achieve
>>>>          > everything desired, and usually deliver everything you could
>>>>         have hoped
>>>>          > for and even more." -Paul Debevec
>>>>     Do you Yahoo!?
>>>>     Friends. Fun. Try the all-new Yahoo! Messenger
>>>>     <http://messenger.yahoo.com/>
>>>> Do you Yahoo!?
