[AG-TECH] Upgrading to 2.2
    ARSC Grid Op's
    agn_tech at yahoo.com
    Thu Jun  3 19:10:30 CDT 2004
Jen,
This is what I did to get this working;
In the dialog box "Add" I entered "localhost" for host value and port '11000'
for port value.  Next under the Service menu I added Audio and Video services.
 After that I went to 'Store Configuration' and saved the configuration under a new name
and set it to default. After that everything worked fine. Hope this helps.
- Eric Peterson
Arctic Region Supercomputing Center
epeterso at arsc.edu
Jennifer Teig von Hoffman <jtvh at bu.edu> wrote:
Thanks Tom!
Could you be a little more specific about how to rebuild the node
configuration using a service manager on port 11000? I've selected
"Service Manager," "Add" within the Node Management window, but I'm not
sure exactly what to enter in the Add Service Manager Dialog box.
- Jennifer
Thomas D. Uram wrote:
> The problem with old node configurations is clear, and has to do with
> the service manager running on a different port.
> When the venue client runs (with the personal node option, which is the
> default from the menus), it starts the node service and service manager.
> The service manager was in previous releases on port 12000; it is now
> on port 11000. Old node configurations will look for the service
> manager on port 12000 and fail. If you rebuild the node configuration
> using a service manager on port 11000, everything should work fine.
> Deb: If you were trying to create a new config using the old port, this
> should fix your problem as well. If not, please forward more detail
> about the problem you're encountering.
> Thanks,
> Tom
> Deb Agarwal wrote:
>> I also get the error loading the default windows config or creating
>> my own manually on Windows XP.
>> Deb
>> Jennifer Teig von Hoffman wrote:
>>> Hmm, I just tried that, and I get errors when I try to load the
>>> defaultWindows config, or either of the other configs I'd created
>>> under 2.1.2b, which apparently were carried over to the new
>>> installation.
>>> - Jennifer
>>> ARSC Grid Op's wrote:
>>>> I got everything working now with Windows 2000 and the new ver. 2.2.
>>>> Seems the problem was the default config file "defaultWindows"
>>>> failed to load. Instead I manually added the local service manager
>>>> and services and that did the trick. Thanks again.
>>>> - Eric Peterson
>>>> I seem to be having the same problem, and I've already
>>>> removed the
>>>> GLOBUS_HOSTNAME variable (as suggested earlier on this
>>>> thread) and
>>>> rebooted for good measure. When I open Node Manager (from
>>>> the Venue
>>>> Client), there doesn't appear to be a ServiceManager running.
>>>> Here's a
>>>> screen shot:
>>>> http://scv.bu.edu/~jtvh/images/error.jpg
>>>> BTW, I do find rat.exe on my hard drive, in AudioService.zip.
>>>> - Jennifer
>>>> Michael Miller wrote:
>>>> > Eric,
>>>> > Check the Node Config and make sure the ServiceManager for
>>>> localhost is
>>>> > on port 11000. This changed in the latest release.
>>>> > Michael Miller
>>>> > NCSA
>>>> > At 02:43 PM 6/2/2004, ARSC Grid Op's wrote:
>>>> >> Hello,
>>>> >> I am currently trying to upgrade a Windows 2000 Machine to
>>>> the new
>>>> >> 2.2 Toolkit released yesterday. W! ! hen I run the Venue
>>>> Client Shortcut,
>>>> >> the program launches, but Rat or Vic never lauch when a
>>>> venue is
>>>> >> selected. I searched for rat.exe and vic.exe and it is not
>>>> present
>>>> >> anywhere on the machine. I have tried reinstalling, but
>>>> with
>>>> the same
>>>> >> results. Any ideas? Thanks.
>>>> >> - Eric Peterson
>>>> >> Fairbanks, Alaska
>>>> >> Do you Yahoo!?
>>>> >> Friends. Fun. Try the all-new Yahoo!
>>>> >> Messenger
>>>> > Thanx,
>>>> > Michael Miller
>>>> > System Engineer
>>>> > Visualization Technology Support
>>>> > Computing and Data Management
>>>> > National Center for Supercomputing Applications
>>>> > University of Illinois - UC
>>>> > 217-649-0747
>>>> > "If you're clear in your vision and trust the people in your
>>>> team with
>>>> > clear objectives, they will! inv! ariably do their best to
>>>> achieve
>>>> > everything desired, and usually deliver everything you could
>>>> have hoped
>>>> > for and even more." -Paul Debevec
>>>> Do you Yahoo!?
>>>> Friends. Fun. Try the all-new Yahoo! Messenger
>>>> Do you Yahoo!?
Do you Yahoo!?
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040603/aba86133/attachment.htm>
