[AG-TECH] Upgrading to 2.2
    Jennifer Teig von Hoffman
    jtvh at bu.edu
    Thu Jun  3 13:38:30 CDT 2004
Hmm, I just tried that, and I get errors when I try to load the
defaultWindows config, or either of the other configs I'd created under
2.1.2b, which apparently were carried over to the new installation.
- Jennifer
ARSC Grid Op's wrote:
> I got everything working now with Windows 2000 and the new ver. 2.2.
> Seems the problem was the default config file "defaultWindows" failed to
> load. Instead I manually added the local service manager and services
> and that did the trick. Thanks again.
> - Eric Peterson
>         I seem to be having the same problem, and I've already removed the
>         GLOBUS_HOSTNAME variable (as suggested earlier on this thread) and
>         rebooted for good measure. When I open Node Manager (from the Venue
>         Client), there doesn't appear to be a ServiceManager running.
>         Here's a
>         screen shot:
>         http://scv.bu.edu/~jtvh/images/error.jpg
>         BTW, I do find rat.exe on my hard drive, in AudioService.zip.
>         - Jennifer
>         Michael Miller wrote:
>          > Eric,
>          > Check the Node Config and make sure the ServiceManager for
>         localhost is
>          > on port 11000. This changed in the latest release.
>          > Michael Miller
>          > NCSA
>          > At 02:43 PM 6/2/2004, ARSC Grid Op's wrote:
>          >> Hello,
>          >> I am currently trying to upgrade a Windows 2000 Machine to
>         the new
>          >> 2.2 Toolkit released yesterday. W! ! hen I run the Venue
>         Client Shortcut,
>          >> the program launches, but Rat or Vic never lauch when a
>         venue is
>          >> selected. I searched for rat.exe and vic.exe and it is not
>         present
>          >> anywhere on the machine. I have tried reinstalling, but with
>         the same
>          >> results. Any ideas? Thanks.
>          >> - Eric Peterson
>          >> Arctic Region Supercomputing Center
>          >> Fairbanks, Alaska
>          >> Do you Yahoo!?
>          >> Friends. Fun. Try the all-new Yahoo!
>          >> Messenger
>          > Thanx,
>          > Michael Miller
>          > System Engineer
>          > Visualization Technology Support
>          > Computing and Data Management
>          > National Center for Supercomputing Applications
>          > University of Illinois - UC
>          > 217-649-0747
>          > "If you're clear in your vision and trust the people in your
>         team with
>          > clear objectives, they will! inv! ariably do their best to
>         achieve
>          > everything desired, and usually deliver everything you could
>         have hoped
>          > for and even more." -Paul Debevec
>     Do you Yahoo!?
>     Friends. Fun. Try the all-new Yahoo! Messenger
>     <http://messenger.yahoo.com/>
> Do you Yahoo!?
