[AG-TECH] Upgrading to 2.2
    ARSC Grid Op's
    agn_tech at yahoo.com
    Thu Jun  3 13:01:29 CDT 2004
I got everything working now with Windows 2000 and the new ver. 2.2. Seems the problem was the default config file "defaultWindows" failed to load. Instead I manually added the local service manager and services and that did the trick. Thanks again.
- Eric Peterson
I seem to be having the same problem, and I've already removed the
GLOBUS_HOSTNAME variable (as suggested earlier on this thread) and
rebooted for good measure. When I open Node Manager (from the Venue
Client), there doesn't appear to be a ServiceManager running. Here's a
screen shot:
http://scv.bu.edu/~jtvh/images/error.jpg
BTW, I do find rat.exe on my hard drive, in AudioService.zip.
- Jennifer
Michael Miller wrote:
> Eric,
> Check the Node Config and make sure the ServiceManager for localhost is
> on port 11000. This changed in the latest release.
> Michael Miller
> NCSA
> At 02:43 PM 6/2/2004, ARSC Grid Op's wrote:
>> Hello,
>> I am currently trying to upgrade a Windows 2000 Machine to the new
>> 2.2 Toolkit released yesterday. W! hen I run the Venue Client Shortcut,
>> the program launches, but Rat or Vic never lauch when a venue is
>> selected. I searched for rat.exe and vic.exe and it is not present
>> anywhere on the machine. I have tried reinstalling, but with the same
>> results. Any ideas? Thanks.
>> - Eric Peterson
>> Arctic Region Supercomputing Center
>> Fairbanks, Alaska
>> Do you Yahoo!?
>> Friends. Fun. Try the all-new Yahoo!
>> Messenger
> Thanx,
> Michael Miller
> System Engineer
> Visualization Technology Support
> Computing and Data Management
> National Center for Supercomputing Applications
> University of Illinois - UC
> 217-649-0747
> "If you're clear in your vision and trust the people in your team with
> clear objectives, they will inv! ariably do their best to achieve
> everything desired, and usually deliver everything you could have hoped
> for and even more." -Paul Debevec
Do you Yahoo!?
Friends. Fun. Try the all-new Yahoo! Messenger
Do you Yahoo!?
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040603/2d7ce8f8/attachment.htm>
