[AG-TECH] Upgrading to 2.2
    ARSC Grid Op's
    agn_tech at yahoo.com
    Wed Jun  2 18:42:34 CDT 2004
I as well have tried removing the GLOBUS_HOSTNAME variable with no luck. I think there might be something wrong with the installer. Because I am not getting rat.exe or vic.exe  files in the /bin dir of the install path. I also have the same screenshot of the service manager as Jennifer. I have tried reinstalling, restarting and re-downloading all the files including active python 2.3, wxpython and the 2.2 toolkit . I was able to get and run the older version of the toolkit (2.1.2) with python 2.2 with no problems. Also selecting exit from the Venue Client causes the program to hang everytime. I have to force quit the client through Task manager in order to kill the process.
- Eric Peterson
Jennifer Teig von Hoffman <jtvh at bu.edu> wrote:
I seem to be having the same problem, and I've already removed the
GLOBUS_HOSTNAME variable (as suggested earlier on this thread) and
rebooted for good measure. When I open Node Manager (from the Venue
Client), there doesn't appear to be a ServiceManager running. Here's a
screen shot:
http://scv.bu.edu/~jtvh/images/error.jpg
BTW, I do find rat.exe on my hard drive, in AudioService.zip.
- Jennifer
Michael Miller wrote:
> Eric,
> Check the Node Config and make sure the ServiceManager for localhost is
> on port 11000. This changed in the latest release.
> Michael Miller
> NCSA
> At 02:43 PM 6/2/2004, ARSC Grid Op's wrote:
>> Hello,
>> I am currently trying to upgrade a Windows 2000 Machine to the new
>> 2.2 Toolkit released yesterday. When I run the Venue Client Shortcut,
>> the program launches, but Rat or Vic never lauch when a venue is
>> selected. I searched for rat.exe and vic.exe and it is not present
>> anywhere on the machine. I have tried reinstalling, but with the same
>> results. Any ideas? Thanks.
>> - Eric Peterson
>> Arctic Region Supercomputing Center
>> Fairbanks, Alaska
>> Do you Yahoo!?
>> Friends. Fun. Try the all-new Yahoo!
>> Messenger
> Thanx,
> Michael Miller
> System Engineer
> Visualization Technology Support
> Computing and Data Management
> National Center for Supercomputing Applications
> University of Illinois - UC
> 217-649-0747
> "If you're clear in your vision and trust the people in your team with
> clear objectives, they will invariably do their best to achieve
> everything desired, and usually deliver everything you could have hoped
> for and even more." -Paul Debevec
Do you Yahoo!?
Friends.  Fun. Try the all-new Yahoo! Messenger
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040602/99e8b2fb/attachment.htm>
