[AG-TECH] Cant run AG2.2 applications...
    Thomas D. Uram
    turam at mcs.anl.gov
    Wed Jun  2 11:20:58 CDT 2004
This problem occurs with earlier versions of python 2.2.2. The interface
to string.strip changed in an update.  You can get an update for redhat
7.3 here:
http://download.fedoralegacy.org/redhat/7.3/updates/i386/python2-2.2.2-11.7.3.i386.rpm
Natalia:  To remove the earlier AG rpms, use 'rpm -e AccessGrid', and
then 'rpm -q AccessGrid' to confirm that they've been removed.
Tom
Nick Giannias wrote:
> I'm having the same problem with the same error being generated. I'm running
> RedHat 7.3 with Gnome.
> thanks
> nick
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
> Behalf Of Natalia Costas Lago
> Sent: Wednesday, June 02, 2004 7:26 AM
> To: ag-tech at mcs.anl.gov
> Subject: [AG-TECH] Cant run AG2.2 applications...
> Hi,
> I'm having trouble trying to execute the AG2.2 Venue Client (1st June final
> version) under Linux (don't know about Windows version yet). Maybe I haven't
> deleted the prior version correctly. Can someone tell me how to delete
> AG2.1.2 and/or AG2.2 (beta) releases? (I did rpm -i of the components I've
> found.
> The error I get is the next:
> [ag at agcontrol AccessGrid-2.2-6]$ VenueClient.py
> Traceback (most recent call last):
>   File "/usr/bin/VenueClient.py", line 107, in ?
>     main()
>   File "/usr/bin/VenueClient.py", line 49, in main
>     app = WXGUIApplication()
>   File "/usr/lib/python2.2/site-packages/AccessGrid/Toolkit.py", line 405,
> in __init__
>     [ ("agpm.py", agpmCmd, "open") ] )
>   File
> "/usr/lib/python2.2/site-packages/AccessGrid/Platform/unix/Config.py", line
> 845, in RegisterMimeType
>     gnomeAppInfo="""
> TypeError: strip() takes no arguments (1 given)
> Thankx in advance.
> Kind regards,
> Natalia.
> PS: I use KDE, in case it is a relevant information.
> PS2: I've deleted /etc/AccessGrid and /home/ag/.AccessGrid prior to AG2.2
> (1st June) installation.
>>The Access Grid Toolkit 2.2 is available for download at:
> http://www.mcs.anl.gov/fl/research/accessgrid/software/releases/2.2/index.ht
>>ml
>>It is strongly recommended that you remove previous versions of the
>>Access Grid Toolkit before installing the 2.2 software. While the 2.2
>>final software should co-exist with previous installations cleanly, the
>>alpha and beta are known to cause problems.
>>This release includes major usability and stability improvements.
>>Highlights include:
>>- Updated to Python 2.3 (on windows)
>>- Update to the latest SOAPpy
>>- Update to newer pyGlobus and Globus Toolkit (on linux)
>>- Streamlined Certificate Management User Interfaces
>>- Support for Service Certificates
>>- Support for an anonymous certificate service
>>- New Node Service Packaging, which supports more flexible Node
>>Services - Shared Applications Developers Tools, Examples and a
>>Programmers Manual - A Venue Client Control Interface (so the Venue
>>Client can be
>>programmatically controlled)
>>- Usage logging in the Venue Server
>>- Automatic reconnection for the Venue Client
>>- Venue Server significantly stabilized, memory leaks plugged.
>>- Double clicking app packages will install them automatically.
>>Known Issues:
>>- Venue Management Tool rewrites address upon connection, after it has
>>connected to the local server.
>>-Detection of some video devices on windows is not working, anything
>>that maps to the video for windows device should work.
>>For more information on this release see the official release page.
>>As always, feedback is desired. Please file bug reports, feature
>>requests, or enhancements via the Access Grid Bugzilla pages
>>(http://bugzilla.mcs.anl.gov/acucessgrid) or via the ag-tech mailing
>>list (mailto:ag-tech at mcs.anl.gov).
>>Thanks,
>>The AG Team
> Natalia Costas Lago
> mailto: natalia at cesga.es
> Centro de Supercomputacion de Galicia (CESGA)
> Avenida de Vigo, s/n Campus Sur
> 15705 Santiago de Compostela - SPAIN
> Tel: +34  981 56 98 10
> Fax: +34  981 59 46 16
> http://www.cesga.es/
