[AG-TECH] Cant run AG2.2 applications...
Eric Olson
eolson at mcs.anl.gov
Wed Jun 2 11:21:48 CDT 2004
Hi Nick,
You can get rid of this error by updating to the latest python2 rpm for
redhat 7.3. I found it here:
http://download.fedoralegacy.org/redhat/7.3/updates/i386/
Currently, the latest version there is: python2-2.2.2-11
Let us know if you run into anything else.
Eric
On Wed, 2 Jun 2004, Nick Giannias wrote:
> I'm having the same problem with the same error being generated. I'm running
> RedHat 7.3 with Gnome.
> thanks
> nick
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
> Behalf Of Natalia Costas Lago
> Sent: Wednesday, June 02, 2004 7:26 AM
> To: ag-tech at mcs.anl.gov
> Subject: [AG-TECH] Cant run AG2.2 applications...
> Hi,
> I'm having trouble trying to execute the AG2.2 Venue Client (1st June final
> version) under Linux (don't know about Windows version yet). Maybe I haven't
> deleted the prior version correctly. Can someone tell me how to delete
> AG2.1.2 and/or AG2.2 (beta) releases? (I did rpm -i of the components I've
> found.
> The error I get is the next:
> [ag at agcontrol AccessGrid-2.2-6]$ VenueClient.py
> Traceback (most recent call last):
> File "/usr/bin/VenueClient.py", line 107, in ?
> main()
> File "/usr/bin/VenueClient.py", line 49, in main
> app = WXGUIApplication()
> File "/usr/lib/python2.2/site-packages/AccessGrid/Toolkit.py", line 405,
> in __init__
> [ ("agpm.py", agpmCmd, "open") ] )
> File
> "/usr/lib/python2.2/site-packages/AccessGrid/Platform/unix/Config.py", line
> 845, in RegisterMimeType
> gnomeAppInfo="""
> TypeError: strip() takes no arguments (1 given)
> Thankx in advance.
> Kind regards,
> Natalia.
> PS: I use KDE, in case it is a relevant information.
> PS2: I've deleted /etc/AccessGrid and /home/ag/.AccessGrid prior to AG2.2
> (1st June) installation.
> > The Access Grid Toolkit 2.2 is available for download at:
> http://www.mcs.anl.gov/fl/research/accessgrid/software/releases/2.2/index.ht
> > ml
> > It is strongly recommended that you remove previous versions of the
> > Access Grid Toolkit before installing the 2.2 software. While the 2.2
> > final software should co-exist with previous installations cleanly, the
> > alpha and beta are known to cause problems.
> > This release includes major usability and stability improvements.
> > Highlights include:
> > - Updated to Python 2.3 (on windows)
> > - Update to the latest SOAPpy
> > - Update to newer pyGlobus and Globus Toolkit (on linux)
> > - Streamlined Certificate Management User Interfaces
> > - Support for Service Certificates
> > - Support for an anonymous certificate service
> > - New Node Service Packaging, which supports more flexible Node
> > Services - Shared Applications Developers Tools, Examples and a
> > Programmers Manual - A Venue Client Control Interface (so the Venue
> > Client can be
> > programmatically controlled)
> > - Usage logging in the Venue Server
> > - Automatic reconnection for the Venue Client
> > - Venue Server significantly stabilized, memory leaks plugged.
> > - Double clicking app packages will install them automatically.
> > Known Issues:
> > - Venue Management Tool rewrites address upon connection, after it has
> > connected to the local server.
> > -Detection of some video devices on windows is not working, anything
> > that maps to the video for windows device should work.
> > For more information on this release see the official release page.
> > As always, feedback is desired. Please file bug reports, feature
> > requests, or enhancements via the Access Grid Bugzilla pages
> > (http://bugzilla.mcs.anl.gov/acucessgrid) or via the ag-tech mailing
> > list (mailto:ag-tech at mcs.anl.gov).
> > Thanks,
> > The AG Team
> Natalia Costas Lago
> mailto: natalia at cesga.es
> Centro de Supercomputacion de Galicia (CESGA)
> Avenida de Vigo, s/n Campus Sur
> 15705 Santiago de Compostela - SPAIN
> Tel: +34 981 56 98 10
> Fax: +34 981 59 46 16
> http://www.cesga.es/
