[AG-TECH] venue client problems
ULM AccessGrid
accessgrid at ulm.edu
Tue Jul 27 08:39:28 CDT 2004
Same here, I get kicked off more often then not. When I first get into the
main venue I usually can stay on about 50% of the time at least for a couple
of hours. For every level I drop down into the venues I only have a 50%
chance again to stay in that venue (50% of 50% is 25% and so on and so
forth). One I get kicked off that's the end. It just kicks and kicks and
etc... The only way to get my chances again is to close the venue client
completely(making sure all python processes die because sometimes they
don't) and restarting the venue client. This gets me back to my chances
again. It usually takes me around 10 times to get into the venue I need to
get into.
And now that you mention it, it does seem to get faster when it invites me
again and then kicks me over and over again.
I am on 2.2 on a Multi-Node with Windows running my Venue Client and audio
and Fedora running my Video.
Just thought that I would let you know it's not just you :-)
Thanks
Adam Taylor
Computing Center
University of Louisiana at Monroe
-----Original Message-----
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On Behalf
Of Markus Buchhorn
Sent: Monday, July 26, 2004 9:47 PM
To: ag-tech at mcs.anl.gov
Subject: [AG-TECH] venue client problems
Hi all at ag-dev
On a 2.2 node (venue client on Windows) I can enter and move around the APAG
venue server (2.1.2 from memory?) fine, but have all sorts of problems
entering and moving around the ANL venue server. Typical behaviour is
1. I get kicked off,
2. I get invited to reconnect
3. I get kicked off before I have fully reconnected
4. Repeat 2-3 at ever faster rate.
Occassionally I get in and can stay in, on the main Lobby venue. If I try
and enter the Institutional Lobby though it takes a looooong time, and then
eventually enters the main Lobby again - not letting me drop down to lower
venues at all. Then after all a while I get kicked off (see above :-) ).
Also: There doesn't seem to be any way to say to the venue client to cancel
an attempt to enter a venue. So if there's any problems getting into a
venue, it effectively hangs the venue client. Timeouts might help, but
there's too many places where some delays might occur. It'd be nice if the
venue client could provide fairly detailed state-information as to where it
is up to when changing venues ('killing/ed rat, killing/ed vic, entering/ed
venue, starting/ed vic, starting/ed rat, things should be normal now, ...'
Is there any plan for a minor update to 2.2 to fix these things (if you know
what is causing them), or is 2.3 close? scglobal is looming.
Cheers,
Markus
Markus Buchhorn, ANU Internet Futures Group, |Ph: +61 2 61258810
Markus.Buchhorn at anu.edu.au, mail: Bldg #108 CS&IT |Fx: +61 2 61259805
The Australian National University, Canberra 0200 |Mob: 0417 281429
