[AG-TECH] venue client problems
Monika Rabarison
monika.k.rabarison at ccaix.jsums.edu
Tue Jul 27 09:18:04 CDT 2004
I am on a 2.2 PIG running on XP and get kicked off and
asked to reconnect about every 5 minutes in the Lobby.
Monika
On Tue, 27 Jul 2004, ULM AccessGrid wrote:
> Same here, I get kicked off more often then not. When I first get into the
> main venue I usually can stay on about 50% of the time at least for a couple
> of hours. For every level I drop down into the venues I only have a 50%
> chance again to stay in that venue (50% of 50% is 25% and so on and so
> forth). One I get kicked off that's the end. It just kicks and kicks and
> etc... The only way to get my chances again is to close the venue client
> completely(making sure all python processes die because sometimes they
> don't) and restarting the venue client. This gets me back to my chances
> again. It usually takes me around 10 times to get into the venue I need to
> get into.
> And now that you mention it, it does seem to get faster when it invites me
> again and then kicks me over and over again.
> I am on 2.2 on a Multi-Node with Windows running my Venue Client and audio
> and Fedora running my Video.
> Just thought that I would let you know it's not just you :-)
> Thanks
> Adam Taylor
> Computing Center
> University of Louisiana at Monroe
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On Behalf
> Of Markus Buchhorn
> Sent: Monday, July 26, 2004 9:47 PM
> To: ag-tech at mcs.anl.gov
> Subject: [AG-TECH] venue client problems
> Hi all at ag-dev
> On a 2.2 node (venue client on Windows) I can enter and move around the APAG
> venue server (2.1.2 from memory?) fine, but have all sorts of problems
> entering and moving around the ANL venue server. Typical behaviour is
> 1. I get kicked off,
> 2. I get invited to reconnect
> 3. I get kicked off before I have fully reconnected
> 4. Repeat 2-3 at ever faster rate.
> Occassionally I get in and can stay in, on the main Lobby venue. If I try
> and enter the Institutional Lobby though it takes a looooong time, and then
> eventually enters the main Lobby again - not letting me drop down to lower
> venues at all. Then after all a while I get kicked off (see above :-) ).
> Also: There doesn't seem to be any way to say to the venue client to cancel
> an attempt to enter a venue. So if there's any problems getting into a
> venue, it effectively hangs the venue client. Timeouts might help, but
> there's too many places where some delays might occur. It'd be nice if the
> venue client could provide fairly detailed state-information as to where it
> is up to when changing venues ('killing/ed rat, killing/ed vic, entering/ed
> venue, starting/ed vic, starting/ed rat, things should be normal now, ...'
> Is there any plan for a minor update to 2.2 to fix these things (if you know
> what is causing them), or is 2.3 close? scglobal is looming.
> Cheers,
> Markus
> Markus Buchhorn, ANU Internet Futures Group, |Ph: +61 2 61258810
> Markus.Buchhorn at anu.edu.au, mail: Bldg #108 CS&IT |Fx: +61 2 61259805
> The Australian National University, Canberra 0200 |Mob: 0417 281429
Monika Rabarison
Systems Administrator
Information Technology/HPCVI
Jackson State University
Office:(601)979-5933
SciVis Lab:(601)979-1061
JSUvisNode:(601)979-1056
JSUeNode:(601)979-1081
