[AG-TECH] New Fedora Core 2 AGTk CVS snapshot
John Hodrien
johnh at comp.leeds.ac.uk
Fri Jul 16 08:57:42 CDT 2004
On Fri, 16 Jul 2004, John Hodrien wrote:
> On Fri, 16 Jul 2004, Douglas Kosovic wrote:
>> I ended up getting a TV Capture card with more than just a composite
>> input and was able to reproduce the problem and then find a possible
>> fix.
> Magic, I'd come across this one too.
> I've got everything looking good apart from audio. I'm getting the following
> output when rat starts up:
> ALSA lib pcm.c:824(snd_pcm_sw_params) snd_pcm_sw_params: params->avail_min
> problem for start_threshold
> Failed to set SW params: invalid argument
> Failed to open device for playback
> Any suggestions, in case people here have fixed this one before?
As an evil follow-up to self, I've managed to remove this error by updating
the alsa-libs to 1.0.4 (there's a bugzilla entry for something similar) from
http://people.redhat.com/~walters/alsa/
Have just been kicked off the AG, as they're using it with AG1, so I can't yet
test it's behaving properly, but it was no longer producing the error on the
command line, so here's hoping.
jh
"I mean, if 10 years from now, when you are doing something quick and dirty,
you suddenly visualize that I am looking over your shoulders and say to
yourself, "Dijkstra would not have liked this", well that would be enough
immortality for me." -- Edsgar Wybe Dijkstra
