[AG-TECH] New Fedora Core 2 AGTk CVS snapshot
Fred Dech
fdech at uchicago.edu
Fri Jul 16 09:03:01 CDT 2004
On Fri, Jul 16, 2004 at 10:04PM, Douglas Kosovic said:
> On Fri, 2004-07-16 at 04:34, Fred Dech wrote:
> > and when vic fires up, i still need to change each video capture from
> > Composite1 to S-Video each time i change venues.
> I ended up getting a TV Capture card with more than just a composite
> input and was able to reproduce the problem and then find a possible
> fix.
> There's a problem with the way vic processes the vic setup script (i.e.
> /tmp/VideoService_*.vic) that VideoService.py generates.
> A patch for VideoService.py can found here:
> http://www.itee.uq.edu.au/~agn/ag_fedora/FC2/unstable/patches/VideoService.py.patch
hi Doug.
i'll grab it straightaway and send you the results i get.
> The VideoService.py file is located in:
> ~/.AccessGrid/local_services/VideoService/
i can start out just testing with VideoService, rather than using Video-
ProducerService.
thanks.
--fred
