[AG-TECH] Error occurred during certificate import
Carter, Tameka
ttcarter at bnl.gov
Fri Jan 30 16:10:48 CST 2004
Hey,
A friend of mine had the same problem. We tried deleting the certrepo
directory and importing again. I was then told the key was not with the
certificate. We then tried to request another certificate 4-5 days ago. We
have not gotten it yet.
On another note, is it the case that any certificate works? I have a DOE
science grid certificate I have been wondering about.
Cheers,
Tameka
-----Original Message-----
Sent: Friday, January 30, 2004 4:52 PM
To: darin at ucar.edu; ag-tech at mcs.anl.gov
Subject: Re: [AG-TECH] Error occurred during certificate import
If you send me your client logfile:
\Documents and Settings\<user>\Application Data\AccessGrid\venueclient.log
I'll take a look and see what I can see. If you moved things around in the
certRepo dir you've likely caused problems, yes. If you did that, remove the
certREpo dir and try the import again.
--bob
At 02:36 PM 1/30/2004, Darin Oman wrote:
I get this error when I try to import a certificate on a Windows machine.
The cert has been exported from Linux. I tried moving various certs and .pem
files around, so I probably screwed things up even worse, but I still get
the same error. Any ideas?
Darin
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040130/81966f15/attachment.htm>
