[AG-TECH] Error occurred during certificate import
Darin Oman
darin at ucar.edu
Fri Jan 30 16:04:46 CST 2004
Thanks for the offer, Bob, but I just got it to work. I ended up uninstalling the toolkit and deleting any leftovers I could find relating to the AG or Globus. Not very technical, but it worked.
Darin
On 1/30/2004 at 3:52 PM Robert Olson wrote:
If you send me your client logfile:
\Documents and Settings\<user>\Application Data\AccessGrid\venueclient.log
I'll take a look and see what I can see. If you moved things around in the certRepo dir you've likely caused problems, yes. If you did that, remove the certREpo dir and try the import again.
--bob
At 02:36 PM 1/30/2004, Darin Oman wrote:
I get this error when I try to import a certificate on a Windows machine. The cert has been exported from Linux. I tried moving various certs and .pem files around, so I probably screwed things up even worse, but I still get the same error. Any ideas?
Darin
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040130/ce6c43b9/attachment.htm>
