[AG-TECH] Error occurred during certificate import
Robert Olson
olson at mcs.anl.gov
Fri Jan 30 15:52:14 CST 2004
If you send me your client logfile:
\Documents and Settings\<user>\Application Data\AccessGrid\venueclient.log
I'll take a look and see what I can see. If you moved things around in the
certRepo dir you've likely caused problems, yes. If you did that, remove
the certREpo dir and try the import again.
--bob
At 02:36 PM 1/30/2004, Darin Oman wrote:
>I get this error when I try to import a certificate on a Windows machine.
>The cert has been exported from Linux. I tried moving various certs and
>.pem files around, so I probably screwed things up even worse, but I still
>get the same error. Any ideas?
>Thanks,
>Darin
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040130/c386cdc7/attachment.htm>
