[AG-TECH] two more certification notes in 2.1.2 early tests
    Todd Zimmerman
    toddz at sfu.ca
    Wed Jan 21 13:53:15 CST 2004
This is an old thread from October 2003 - however I'm running into the
same problem.
Was this issue ever resolved???
Thanks
todd
Collaboration & Visualization Technician
WestGrid - www.westgrid.ca
Ph. 604.268.6979
Todd Zimmerman - toddz at sfu.ca
Robert Olson wrote:
> Hi --
> If you send me the logfiles from your Application Data\AccessGrid
> directory I can try to figure out what's going on.
> thanks,
> --bob
> At 11:32 AM 10/27/2003, Lewis Grantham wrote:
>> Hi AG team,
>> great job on 2.1.2.. I finally got it to go, and looks good.  the cert
>> management opens up some interesting avenues, and no doubt this will
>> develop
>> further.
>> have noticed two points in this respect for the record though:
>> a. at sometime setting up 2.1.1b I suppose, I managed to create empty
>> directories in the Application Data\AccessGrid\certRepo\certificates
>> folder
>> (with names like d9f469c3c3133747f615ff01fc121f21).  could be part of
>> the
>> (fixed) issue with policies from 0-starting CAs, or just me. Had no
>> luck getting
>> things settled until i cleared these.  the aguninstall.py script
>> seemed to
>> preserve them too, so my problems just carried on with 2.1.2 intially.
>> b. the AGTK can use a UK E-Science cert in some repsects.  Imports ok
>> after CA
>> import, and seems to proxy ok when set as default.  However, any
>> AGService and
>> AGNodeService I run with this set up dont seem to work properly.  The
>> scripts
>> run, and logs look like:
>> C:\Program Files\Access Grid Toolkit\bin>AGNodeservice -d
>> AGNodeService URL:  https://boshtv.mediares.ucl.ac.uk:11000/NodeService
>> C:\Program Files\Access Grid Toolkit\bin>AGserviceManager -d
>> AGServiceManager URL:
>> https://boshtv.mediares.ucl.ac.uk:12000/ServiceManager
>> VenueClient logs look ok, but when you connect to a venue, no
>> services are
>> spawned to handle video or audio.
>> If I try to 'Manage my node' from the prefs menu, it fails with the
>> following
>> debugs:
>> 10/27/03 17:15:59 DEBUG HaveValidProxy: found proxy ident
>> /C=UK/O=eScience/OU=UC
>> L/L=EISD/CN=lewis grantham/CN=proxy
>> Invalid Node Service URI:
>> and a dialogue saying a more human version of same (Cannot open node..)
>> This only occurs with a different default user cert, and concerns me
>> if end
>> users can make these sorts of changes to installed systems and stop them
>> working.
>> so,
>> Is it the case that the node configuration and service parameters are
>> unique to
>> each imported/default ID?
>> Since NodeManagement script doesn't seem to run from the command line
>> anymore
>> reliably (i've only successfully managed my node with the
>> venueclient>prefs
>> entry), any way I can check whether this is a null or missing service
>> config or
>> something deeper?
>> if simple config issue, any way to brace the systems here to hold a
>> solid config
>> even if some user imports a personal certificate (from wherever) and
>> sets it as
>> default?
>> sounds like it goes against the spirit of the latest changes I know.
>> I am all
>> for user/group personalisations, as its one of the main area of this
>> as a
>> service that worries me.  but seems somethings might be amiss here.
>> many thanks
>> lewis
>> Lewis Grantham LLB MSc
>> Project Leader, Multimedia Unit
>> Media Resources, UCL (University College London)
>> Windeyer Building, Cleveland Street, London W1P 6DB
>> Tel: (+44) 020 7679 9258    Fax: (+44) 020 7580 0995
>> URL: http://www.ucl.ac.uk/mediares/mmedia
