[AG-TECH] New Camera - Got it!
Ronald Crummett
ron_crummett at hotmail.com
Wed Jan 21 13:59:18 CST 2004
Hello -
Well, I somehow figured out what was going on with my camera and it is
working fine now. Thanks for all the help and suggestions; it gave me a lot
to start off of and gave me the courage to go poking around a little more.
If anyone has any advice for me on how to verify and configure multicast
now, I'd greatly appreciate that.
-Ron Crummett
>From: "Ronald Crummett" <ron_crummett at hotmail.com>
>To: derksl at unm.edu, ag-tech at mcs.anl.gov
>CC: bigdaddychuck at juno.com
>Subject: Re: [AG-TECH] New Camera
>Date: Wed, 21 Jan 2004 12:33:44 -0700
>When I use the camera with other applications I can see everything fine. I
>have tried adjusting the configuration as mentioned, but it doesn't help
>all that much. I can almost see myself in the video now, but still not
>nearly as good as when I am using other programs. Any further suggestions?
> Thanks again!
>>From: "Lee Derks" <derksl at unm.edu>
>>To: "Ronald Crummett" <ron_crummett at hotmail.com>, <ag-tech at mcs.anl.gov>
>>CC: <bigdaddychuck at juno.com>
>>Date: Tue, 20 Jan 2004 13:34:38 -0700
>>Hello,
>> Are you able to see the video image clearly in other applications,
>>such
>>as programs that came with the video camera? You may want to check the
>>encoder you are using in the VIC. One of the preferred encoder's is h261.
>>Also, you may want to go through the steps of "configure on transmit." To
>>configure on transmit, click on "options" --> "configure on transmit",
>>click
>>on "release" and then "transmit." Make sure that the resolution is set to
>>the appropriate size, click "ok" and then check the brightness, contrast,
>>saturation, and hue settings.
>>Good luck
>>Lee Derks
>>----- Original Message -----
>>To: <ag-tech at mcs.anl.gov>
>>Cc: <bigdaddychuck at juno.com>
>>Sent: Tuesday, January 20, 2004 10:10 AM
>>Subject: [AG-TECH] New Camera
>> > I have been working on setting up a laptop node on my Compaq Presario
>>2100.
>> > Initially I was using a standard digital camera operating in a PC
>>camera
>> > mode. I recently purchased a real PC camera, a Veo Mobile Camera. But
>>when
>> > I try connecting to the grid using this camera, I don't get a clear
>>image
>>at
>> > all - in fact, all I really see is a red display with a few other
>>colors
>> > moving on occasion. What would cause this, and what would I need to do
>>to
>> > fix it?
>> > In other problems, I cannot see anyone else when I do connect to the
>> > AccessGrid. I have been told that this is most likely a multicast
>>problem
>> > and that sounds reasonable, but I still don't know how to verify that
>>or
>> > what can be done about that. Any ideas? Your help is greatly
>>appreciated
>> > and will continue to be greatly appreciated.
>> > -Ron Crummett
>> > _________________________________________________________________
>> > Check out the coupons and bargains on MSN Offers!
>> > http://shopping.msn.com/softcontent/softcontent.aspx?scmId=1418
Let the new MSN Premium Internet Software make the most of your high-speed
experience. http://join.msn.com/?pgmarket=en-us&page=byoa/prem&ST=1
