[AG-TECH] hauppauge video problems
Bob Riddle
bdr at internet2.edu
Wed Feb 11 09:58:47 CST 2004
yeah - I guess I knew that, but couldn't drag it out of the old, gray,
brain cells. There are/were some old VfW drivers, but at that point it
occurred to me I had spent more on time than on Osprey cards.
Thanks for clearing up my confused babble!
Ti Leggett wrote:
>Actually the problem is this. Vic can only handle Video for Windows (VfW
>devices) which is an old driver style. vic can map the newer WDM drivers
>to a VfW device, but it can only do that for one device. Basically, if
>you have drivers that are VfW then all of them will be seen and usable
>in vic. If the drivers are WDM only, then vic will pick a device and map
>and that's it. Hauppage has stopped providing VfW drivers for their
>cards. Osprey, however, still provides VfW drivers for their cards.
>This driver issue is also why you can only have one web cam hooked up
>since, I'd say, all web cams provide only WDM drivers.
>Make more sense?
>On Wed, 2004-02-11 at 08:35, Bob Riddle wrote:
>>for what it's worth - I've been down this road and gave up - while this
>>is no problem on Linux, the driver for WinXP assumes that only one WinTV
>>card will be on the system. It cost less for a couple of Osprey100
>>cards than it did for the time I spent on trying to make this work.
>>sigh.
>>Harold Micheal Goldman wrote:
>>> Does anyone know of any way to get two hauppauge WinTv video capture cards to
>>>work at the same time in Windows XP. I am creating an Access Grid Node here at
>>>the University of Southern Mississippi for Collaboration for Genomic Research.
>>>I will also be setting up similar agn's at four othe universities here in the
>>>state. I had bought the two cards on the advice of a friend that admins a agn
>>>for the computer science dept here at usm, but we cannot get both cards to work
>>>under xp.
>>>Thank You
>>>Mike Goldman
>>>Bioinformatics Coordinator
>>>MFGN USM
Bob Riddle (bdr at internet2.edu) Technologist,Internet2
3025 Boardwalk, Suite 100 Ann Arbor, Michigan 48108
Business Phone: 734.913.4257 Fax Number: 734.913.4255
"Opportunity is missed by most people because it is dressed in overalls and looks like work" Thomas Edison
