[AG-TECH] hauppauge video problems
Bob Riddle
bdr at internet2.edu
Wed Feb 11 10:19:00 CST 2004
I actually use a Spectra8 card on our "loaner" AG - it has four video
ports on it and works the way Michael describes. I've been trying to do
the same thing with a 4-port Winnov card as well ... (you know, there
are only so many PCI port in a one-box node!)
Michael Miller wrote:
> Just to add to what Ti said:
> My experience has been that, depending on the driver, you can select
> the WDM device in the configuration of multiple VideoProducers. When
> vic starts up, one of the WDM cameras is automatically selected for
> the first VideoProducer. Then you are given a series of dialogs to
> choose a camera for each remaining VideoProducer. Again, whether you
> get to choose another camera will depend on how the driver enumerates
> the cameras. The QuickCam Pro 4000 does show you multiple cameras,
> but it gives them all the same name. So, it can be confusing when
> trying to choose a camera for the subsequent VideoProducers. If you
> have two different cameras, the WDM drivers will assign names as
> appropriate and it's much easier to decide which camera to choose. I
> have an iBot firewire camera and a QuickCam Pro 4000 so I can see
> which camera has become the default after the last session. If you
> have two of the same camera and the driver doesn't assign each a
> unique name, that's when you run into trouble.
> HTH
> Michael Miller
> NCSA
> At 05:36 PM 2/10/2004, Ti Leggett wrote:
>> Actually the problem is this. Vic can only handle Video for Windows (VfW
>> devices) which is an old driver style. vic can map the newer WDM drivers
>> to a VfW device, but it can only do that for one device. Basically, if
>> you have drivers that are VfW then all of them will be seen and usable
>> in vic. If the drivers are WDM only, then vic will pick a device and map
>> and that's it. Hauppage has stopped providing VfW drivers for their
>> cards. Osprey, however, still provides VfW drivers for their cards.
>> This driver issue is also why you can only have one web cam hooked up
>> since, I'd say, all web cams provide only WDM drivers.
>> Make more sense?
>> On Wed, 2004-02-11 at 08:35, Bob Riddle wrote:
>> > for what it's worth - I've been down this road and gave up - while
>> this
>> > is no problem on Linux, the driver for WinXP assumes that only one
>> WinTV
>> > card will be on the system. It cost less for a couple of Osprey100
>> > cards than it did for the time I spent on trying to make this work.
>> > sigh.
>> > Harold Micheal Goldman wrote:
>> > > Does anyone know of any way to get two hauppauge WinTv video
>> capture cards to
>> > >work at the same time in Windows XP. I am creating an Access Grid
>> Node here at
>> > >the University of Southern Mississippi for Collaboration for
>> Genomic Research.
>> > >I will also be setting up similar agn's at four othe universities
>> here in the
>> > >state. I had bought the two cards on the advice of a friend that
>> admins a agn
>> > >for the computer science dept here at usm, but we cannot get both
>> cards to work
>> > >under xp.
>> > > Thank You
>> > > Mike Goldman
>> > > Bioinformatics Coordinator
>> > > MFGN USM
> Thanx,
> Michael Miller
> System Engineer
> Visualization Technology Support
> Computing and Data Management
> National Center for Supercomputing Applications
> University of Illinois - UC
> 217-649-0747
> "If you're clear in your vision and trust the people in your team with
> clear objectives, they will invariably do their best to achieve
> everything desired, and usually deliver everything you could have
> hoped for and even more." -Paul Debevec
Bob Riddle (bdr at internet2.edu) Technologist,Internet2
3025 Boardwalk, Suite 100 Ann Arbor, Michigan 48108
Business Phone: 734.913.4257 Fax Number: 734.913.4255
"Opportunity is missed by most people because it is dressed in overalls and looks like work" Thomas Edison
