[AG-TECH] Vic Preferences and double windows
Douglas Baggett
dbaggett at cise-nsf.gov
Tue Feb 10 14:06:47 CST 2004
Thanks! I'll try that out.
-Doug B
CISE/NSF
Jeremy Mann wrote:
>Douglas Baggett said:
>>Sorry in advance if this question has been asked before.
>>I just installed the AG 2 software and got it up and running. Everything
>>seems to be working ok except for two strange things. Vic seems vic is
>>transmitting two mirror windows when it only should transmit one (I have
>>one camera). Also, the slider in vic has a max of 128Kb and I have far
>>more bandwidth that that. Is there a way to modify the max bandwidth on
>>the slider?
>>I'm using a 3Com Homeconnect with the latest vicam drivers for Widows XP.
>I've seen the two window problem with XP, but not with Linux. I have found
>that if you disable the Consumer service, you'll just be left with the Vic
>window for Producer service.
>I had the same problem with the slider bar. To fix it, I had to create a
>.vic.tcl file. In Linux, I just put it in my home directory, but Windows,
>I don't know, you'll have to experiment with that. But create a .vic.tcl
>and
>add this to the file:
>option add Vic.maxbw 3072 50
>option add Vic.bandwidth 900 50
>option add Vic.framerate 25 50
>option add Vic.quality 85 75
>option add Vic.defaultTTL 127
>Now the others are just optional, but set quite a lot of things.
>Good luck!
