[AG-TECH] hauppauge video problems
Michael Miller
mimiller at ncsa.uiuc.edu
Wed Feb 11 09:27:51 CST 2004
Just to add to what Ti said:
My experience has been that, depending on the driver, you can select the
WDM device in the configuration of multiple VideoProducers. When vic
starts up, one of the WDM cameras is automatically selected for the first
VideoProducer. Then you are given a series of dialogs to choose a camera
for each remaining VideoProducer. Again, whether you get to choose another
camera will depend on how the driver enumerates the cameras. The QuickCam
Pro 4000 does show you multiple cameras, but it gives them all the same
name. So, it can be confusing when trying to choose a camera for the
subsequent VideoProducers. If you have two different cameras, the WDM
drivers will assign names as appropriate and it's much easier to decide
which camera to choose. I have an iBot firewire camera and a QuickCam Pro
4000 so I can see which camera has become the default after the last
session. If you have two of the same camera and the driver doesn't assign
each a unique name, that's when you run into trouble.
HTH
Michael Miller
NCSA
At 05:36 PM 2/10/2004, Ti Leggett wrote:
>Actually the problem is this. Vic can only handle Video for Windows (VfW
>devices) which is an old driver style. vic can map the newer WDM drivers
>to a VfW device, but it can only do that for one device. Basically, if
>you have drivers that are VfW then all of them will be seen and usable
>in vic. If the drivers are WDM only, then vic will pick a device and map
>and that's it. Hauppage has stopped providing VfW drivers for their
>cards. Osprey, however, still provides VfW drivers for their cards.
>This driver issue is also why you can only have one web cam hooked up
>since, I'd say, all web cams provide only WDM drivers.
>Make more sense?
>On Wed, 2004-02-11 at 08:35, Bob Riddle wrote:
> > for what it's worth - I've been down this road and gave up - while this
> > is no problem on Linux, the driver for WinXP assumes that only one WinTV
> > card will be on the system. It cost less for a couple of Osprey100
> > cards than it did for the time I spent on trying to make this work.
> > sigh.
> > Harold Micheal Goldman wrote:
> > > Does anyone know of any way to get two hauppauge WinTv video capture
> cards to
> > >work at the same time in Windows XP. I am creating an Access Grid Node
> here at
> > >the University of Southern Mississippi for Collaboration for Genomic
> Research.
> > >I will also be setting up similar agn's at four othe universities here
> in the
> > >state. I had bought the two cards on the advice of a friend that
> admins a agn
> > >for the computer science dept here at usm, but we cannot get both
> cards to work
> > >under xp.
> > > Thank You
> > > Mike Goldman
> > > Bioinformatics Coordinator
> > > MFGN USM
Thanx,
Michael Miller
System Engineer
Visualization Technology Support
Computing and Data Management
National Center for Supercomputing Applications
University of Illinois - UC
217-649-0747
"If you're clear in your vision and trust the people in your team with
clear objectives, they will invariably do their best to achieve everything
desired, and usually deliver everything you could have hoped for and even
more." -Paul Debevec
