[AG-TECH] Nothing happens....
Jimmy Miklavcic
jhm at chpc.utah.edu
Wed Dec 22 12:07:53 CST 2004
Patrick, I've loaded AGtk 2.3 many times and I have not had any
problems. Here's a quick step by step. I'me sure you've done this but at
least you can see if you missed something.
This is important, uninstall any previous version of all three packages!
Download from AG website.
ActiveSta1e Python 2.3 (ActivePython-2.3.2-232-win32-ix86.msi)
wxPython 2.5 (wxPythonWIN32-2.5.1.5-Py23.exe)
Access Grid Toolkit 2.3 (AGTk-2.3-Py-2.3.exe)
Install each in the order above.
Make sure that the compile python box is checked when you install wxPython.
Reboot.
Run AG venue client and request a certificate.
If you have a certificate on another machine, export the certificate as
a single file from the certificate manager, copy that file to you laptop
and import it.
It was that simple for me.
I hope this helps.
Jimmy
Patrick wrote:
>Hello to all:
>I need some help! I have spent this entire work week trying to
>download the necessary sotware that will allow me access to the
>AccessGrid using my laptop running on WindowsXP. Much of me wants to
>just give up on the idea of viewing on-line seminars through this
>forum, but my competitive nature doesn't want to let technology beat
>me.
>After several downloads and installations and uninstallations of
>Active State python, wx python, and AGTk and many error messages
>saying that python 2.2 was not found in the registry or the shortcut
>for pythonw.exe has been changed or removed.....I recognized that the
>installation of AGTk2.3 required the following software be installed
>first: Active state python 2.3 and wxpython 2.5 or higher.
>So, I did download and install without incidence the following
>versions in their respective order: Active state python 2.3.4,
>wxpython2.5-win32-unicode2.5.3.1-py24,
>wxpython2.5-win32-docs-demos-2.5.3.1, and AGTk-2.3-py-2.3.exe
>However, and here is my new problem, when I click on the new icon that
>appears on my desktop for AGTk nothing happens!
>If I open the programs list and select the AGTk tab/configure/node
>management or node setup wizard, nothing happens!
>If I click on the tab for requesting a certificate, nothing happens!
>Is this really what is supposed to happen? How can I get on the grid?
>Thanks to anyone with some answers. I must warn you that I am not
>very computer literate so I may need the sesame street version of a
>response.
>Thanks, again
>Patrick
Jimmy Miklavcic
Multimedia Specialist
UNIVERSITY OF UTAH
CTR FOR HIGH PERFORM COMPUTING
155 SOUTH 1452 EAST RM 405
SALT LAKE CITY, UT 84112-0190
Office: 801.585.9335
Fax: 801.585.5366
http://www.chpc.utah.edu/~jhm
http://www.anotherlanguage.org
