[AG-TECH] Local Venue Server problem...
Lijuan Geng
fengfenglili2004 at yahoo.com.sg
Tue Dec 21 20:13:09 CST 2004
Hello,
After setting up a local server, I find another problem: If I want to communicate with another AG node locates at a different LAN. How do I make my local Venue Server recognized/accessed by nodes on other networks?
Lijuan
Lijuan Geng <fengfenglili2004 at yahoo.com.sg> wrote:
Hi, Tom
Thank you very much for all the ideas!
The problem has been solved. Previously pc1 could not resolve the hostname of pc2, so when I entered the server address of pc2, pc1 cannot recognize it.
Now everything works and the response of Shared Applications is much faster.
Thanks! :)
Lijuan
"Thomas D. Uram" <turam at mcs.anl.gov> wrote:
Lijuan:
You can try the following:
- Make sure that pc1 can resolve the hostname of pc2, and vice versa.
- Make sure the time on each pc is synchronized to an ntp server.
- Look in the VenueClient.log and VenueServer.log files for an indication of the problem;
send the logfiles to me if you can't see any problem there, and I'll have a look.
Tom
Lijuan Geng wrote:
> Hello,
> I have set up a Local Venue Server to improve the Shared Application Speed.
> The situation is: Server on pc1 can only be connected by the Venue
> Client on pc1, while Server on pc2 can only be connected by Venue Client
> on pc2. When I try to use the Venue Client on pc1 to connect to Server
> on pc2, the connection cannot be established.
> Network no problem. In Venue Management Tool, I didn't! set anything
> special. I wonder if other settings are wrong?
> Please give me some suggestions, Thanks!!
> Lijuan
> */"Thomas D. Uram" /* wrote:
> Lijuan:
> Yes, you can run a VenueServer closer to your client(s) to speed up
> interactions (event
> distribution) in shared applications. Running a venue server is
> quite simple; you can
> find details in the Venue Management manual here:
> http://www.mcs.anl.gov/fl/research/accessgrid/documentation/VENUE_MANAGEMENT_MANUAL_HTML/VenueManagementManualHTML.htm
> One detail that's not entirely clear there is the exact command line
> needed to start a
> server on Linux. You can just run 'VenueServer.py' to start the
> venue server, and use the
> '-h' option to see other options for running the venue server.
> Tom
&! gt;
> Lijuan Geng wrote:
> > Hi,
> > When I launch Shared Applications, the delay from the controller
> > computer to other computers is too long. Since the controller
> > computer commands have to be sent to Venue Server, then from Venue
> > Server to other computers. If the Venue Server is quite far away,
> > then the delay will be very long.
> > I wonder if a local venue server can be set up so that the Shared
> > Application speed can be improved?
> > Lijuan
> > * Yahoo! Mobile
> > - Download the latest ringtones, games, and more!
> * Yahoo! Mobile
Yahoo! Mobile
Yahoo! Mobile
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20041222/9250e821/attachment.htm>
