[AG-TECH] KVM switch problems
Natalia Costas Lago
natalia at cesga.es
Fri Dec 17 02:41:24 CST 2004
i added to lilo.conf an append line with "psmouse.proto=imps". It helped me
with RH 7.3.
image=...
label=...
append="... psmouse.proto=imps"
Tell me whether it works for u or not. Be carefull.. if u unplug the mouse
from the kvm cable.. i found no solution to avoid the same effect.
----- Original Message -----
To: <accessgrid-l at lists.grangenet.net>; <ag-tech at mcs.anl.gov>
Sent: Friday, December 17, 2004 12:35 AM
Subject: [AG-TECH] KVM switch problems
> G'day All
> I have been having some problems with KVM switches in relation to using
> Redhat Fedora, in particular Fedora Core 2 and 3.
> Basically what happens is that the mouse moves very strangely and reacts
> like it is possessed. It jumps all over the screen and clicks
> everywhere. I have had this occur with a number of different KVM
> switches.
> In one example, I had a KVM switch that worked fine on RedHat 7.3, 9.0
> and FC1, but wouldn't work correctly for FC2 and FC3.
> Anyone else experienced similar problems??? If so, do you know of a
> solution or could recommend a good KVM switch in which will work fine.
> Thanks in advance,
> Jason.
> Jason Bell, B.I.T.
> B. Info. Tech. (Honours) Student
> Network Engineer
> Information Technology Division
> Central Queensland University
> High Performance Computing Support Officer
> Research Assistant to the Nonlinear Intelligent Systems Research Group
> Faculty of Informatics & Communication
> E-mail : j.bell at cqu.edu.au
> Phone : 07 4930 9229
> Patience is a virtue.
> But if I wanted Patience,
> I would have become a Doctor.
