[AG-TECH] Re: [AG-L] KVM switch problems
    Rhys Hawkins
    Rhys.Hawkins at anu.edu.au
    Thu Dec 16 17:44:06 CST 2004
Hi Jason,
A workaround is to switch into text mode then switch back into
the X display using the ctrl-alt-function keys. Not great but
better than nothing.
Originally our KVM's had this problem, then they didn't and then
they did again???
I haven't had the same problem with a USB KVM and gentoo, although
if I change computers on a text display, sometimes the display
is frozen and I have to press ctrl-q to unfreeze it. X display
works fine.
Cheers,
    Rhys
On Fri, 2004-12-17 at 09:35 +1000, Jason Bell wrote:
> G'day All
> I have been having some problems with KVM switches in relation to using
> Redhat Fedora, in particular Fedora Core 2 and 3.
> Basically what happens is that the mouse moves very strangely and reacts
> like it is possessed.  It jumps all over the screen and clicks
> everywhere.  I have had this occur with a number of different KVM
> switches.
> In one example, I had a KVM switch that worked fine on RedHat 7.3, 9.0
> and FC1, but wouldn't work correctly for FC2 and FC3.
> Anyone else experienced similar problems???  If so, do you know of a
> solution or could recommend a good KVM switch in which will work fine.
> Thanks in advance,
> Jason.
> Jason Bell, B.I.T.
> B. Info. Tech. (Honours) Student
> Network Engineer
> Information Technology Division
> Central Queensland University
> High Performance Computing Support Officer
> Research Assistant to the Nonlinear Intelligent Systems Research Group
> Faculty of Informatics & Communication
> E-mail : j.bell at cqu.edu.au
> Phone : 07 4930 9229
> Patience is a virtue.
> But if I wanted Patience,
> I would have become a Doctor.
> accessgrid-l mailing list
> accessgrid-l at lists.grangenet.net
> http://lists.grangenet.net/mailman/listinfo/accessgrid-l
