[AG-TECH] Re: Shared Application Problem
    Thomas D. Uram
    turam at mcs.anl.gov
    Tue Dec 14 12:07:22 CST 2004
Lijuan:
Yes, you can run a VenueServer closer to your client(s) to speed up interactions (event
distribution) in shared applications.  Running a venue server is quite simple; you can
find details in the Venue Management manual here:
http://www.mcs.anl.gov/fl/research/accessgrid/documentation/VENUE_MANAGEMENT_MANUAL_HTML/VenueManagementManualHTML.htm
One detail that's not entirely clear there is the exact command line needed to start a
server on Linux.  You can just run 'VenueServer.py' to start the venue server, and use the
'-h' option to see other options for running the venue server.
Tom
Lijuan Geng wrote:
>     Hi,
>     When I launch Shared Applications, the delay from the controller
>     computer to other computers is too long. Since the controller
>     computer commands have to be sent to Venue Server, then from Venue
>     Server to other computers. If the Venue Server is quite far away,
>     then the delay will be very long.
>     I wonder if a local venue server can be set up so that the Shared
>     Application speed can be improved?
>     Please give me some suggestions, Thanks!
>     Lijuan
> * Yahoo! Mobile
> <http://sg.rd.yahoo.com/mail/tagline/?http://sg.mobile.yahoo.com/>*
> - Download the latest ringtones, games, and more!
