[AG-TECH] Re: Shared Application Problem
Lijuan Geng
fengfenglili2004 at yahoo.com.sg
Mon Dec 20 21:46:47 CST 2004
Hello,
I have set up a Local Venue Server to improve the Shared Application Speed.
The situation is: Server on pc1 can only be connected by the Venue Client on pc1, while Server on pc2 can only be connected by Venue Client on pc2. When I try to use the Venue Client on pc1 to connect to Server on pc2, the connection cannot be established.
Network no problem. In Venue Management Tool, I didn't set anything special. I wonder if other settings are wrong?
Please give me some suggestions, Thanks!!
Lijuan
"Thomas D. Uram" <turam at mcs.anl.gov> wrote:
Lijuan:
Yes, you can run a VenueServer closer to your client(s) to speed up interactions (event
distribution) in shared applications. Running a venue server is quite simple; you can
find details in the Venue Management manual here:
http://www.mcs.anl.gov/fl/research/accessgrid/documentation/VENUE_MANAGEMENT_MANUAL_HTML/VenueManagementManualHTML.htm
One detail that's not entirely clear there is the exact command line needed to start a
server on Linux. You can just run 'VenueServer.py' to start the venue server, and use the
'-h' option to see other options for running the venue server.
Tom
Lijuan Geng wrote:
> Hi,
> When I launch Shared Applications, the delay from the controller
> computer to other computers is too long. Since the controller
> computer commands have to be sent to Venue Server, then from Venue
> Server to other computers. If the Venue Server is quite far away,
> then the delay will be very long.
> I wonder if a local venue server can be set up so that the Shared
> Application speed can be improved?
> Lijuan
> * Yahoo! Mobile
> - Download the latest ringtones, games, and more!
Yahoo! Mobile
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20041221/dd5f6424/attachment.htm>
