[AG-TECH] CVS AGTk client cannot connect to default server (RH9.0)
    David G Mills
    dgm at ecs.soton.ac.uk
    Fri Aug 20 05:20:18 CDT 2004
On Thu, 19 Aug 2004, Socrates Varakliotis wrote:
> Right, David, this is something I was wondering about:
> How do we know which version of AG matches which globus?
come on AG guys, we need to know this...
> I've downloaded the pre-WS data management client bundle:
> globus-data-management-client-3.2.1-src_bundle.tar.gz
> from:
> http://www-unix.globus.org/toolkit/downloads/3.2.1/#pre-ws-bundles
> This is what I read in:
> http://www-unix.mcs.anl.gov/fl/research/accessgrid/software/cvs-instructions.html
the newer gt3 version should contain the older gt2 cold as well, but if
you want to just get the gt2 stuff then the best way is from cvs and
specifying the version number in the tag so you get the right cvs branch.
> The paragraph on Linux says:
> 1. Have Globus 2.4.3 installed, instructions for that are elsewhere.
> (you only *need* the globus-data-management-client bundle)
> Where exactly are the instructions you mention? And where is globus 2.4.3?
> AFAIK, the latest stable globus release is 3.2.1.
the instructions I got were from a mailing list, the pyGlobus one, you'd
be hard pressed to actually fine any documentation on any of the actual
web sites.
Dave.
> Any help, please?
> Best Regards,
> Socrates
> From: "David G Mills" <dgm at ecs.soton.ac.uk>
> To: "Thomas D. Uram" <turam at mcs.anl.gov>
> Cc: "Socrates Varakliotis" <S.Varakliotis at cs.ucl.ac.uk>; "ag-tech"
> <ag-tech at mcs.anl.gov>
> Sent: Thursday, August 19, 2004 11:06 AM
> Subject: Re: [AG-TECH] CVS AGTk client cannot connect to default server
> (RH9.0)
> > so what versions of the globus toolkit do the various versions of AG
> > require? and is this stated somewhere??
> > cheers,
> > David.
> > On Wed, 18 Aug 2004, Thomas D. Uram wrote:
> > > The 'xio' here indicates that post-2.4.3 globus was used.  AG 2.x relies
> > > on globus 2.4.3, so if you install that and build pyGlobus against it,
> > > this problem will be resolved.
> > > Tom
> > >  > GSITCPSocketException: globus_xio_gsi: gss_init_sec_context failed.
> > > > Dear All:
> > > > I installed the cvs version of the AGTk on RH9.0.
> > > > I also requested and was issued with a valid certificate, which I
> > > > imported successfully. After launching the Venu Client with:
> > > > prompt> python2.3 AccessGrid/bin/VenueClient.py --debug
> > > > I cannot connect to the default venue at ANL. The output on the screen
> > > > follows. The client's log file is also attached.
> > > > Any help appreciated.
> > > > Best Regards,
> > > > 18/08/04 16:14:11 1074896032 Platform     Config.py:341 DEBUG
> retrieved local IP address 128.16.66.76
> > > > 18/08/04 16:14:11 1074896032 CertificateManager
> CertificateManager.py:263 DEBUG Opened repository
> /root/.AccessGrid/Config/certRepo
> CertificateManager.py:729 DEBUG Configuring standard environment
> CertificateManager.py:797 DEBUG Using default identity /O=Access
> Grid/OU=agdev-ca.mcs.anl.gov/OU=cs.ucl.ac.uk/CN=Socrates Varakliotis2
> CertificateManager.py:868 DEBUG Initializing environment with proxy cert for
> /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=cs.ucl.ac.uk/CN=Socrates
> Varakliotis2
> CertificateManager.py:887 DEBUG Configuring for user proxy issued from
> Varakliotis2
> CertificateManager.py:890 DEBUG Proxy /tmp/x509up_u0 will expire 18/08/04
> 20:27:23
> > > > 18/08/04 16:14:11 1074896032 VenueClient     VenueClient.py:293 DEBUG
> __StartWebService: venueclient: https://128.16.66.76:64182/VenueClient
> > > > 18/08/04 16:14:11 1074896032 VenueClient     VenueClient.py:191 DEBUG
> __createPersonalDataStore: Creating personal datastore at
> /root/.AccessGrid/Config/personalDataStore using prefix personalDataStore
> and port 0
> > > > 18/08/04 16:14:11 1074896032 DataStore     DataStore.py:1512 DEBUG
> Creating thread 0
> > > > 18/08/04 16:14:11 1074896032 DataStore     DataStore.py:1517 DEBUG
> Starting thread 0
> > > > 18/08/04 16:14:11 1074896032 DataStore     DataStore.py:1519 DEBUG
> Waiting thread 0
> > > > 18/08/04 16:14:11 1142135600 DataStore     DataStore.py:1525 DEBUG
> Worker 0 starting
> > > > 18/08/04 16:14:11 1074896032 DataStore     DataStore.py:1522 DEBUG
> Done creating workers
> > > > 18/08/04 16:14:11 1074896032 DataStore     DataStore.py:270 DEBUG
> Reading persisted data from:
> /root/.AccessGrid/Config/personalDataStore/DataStore.dat
> > > > 18/08/04 16:14:11 1074896032 VenueClient     VenueClient.py:216 DEBUG
> __createPersonalDataStore: Load personal data from file
> > > > 18/08/04 16:14:11 1074896032 VenueClientController
> VenueClientController.py:1343 DEBUG There is no personal venues file to
> load.
> > > > 18/08/04 16:14:18 1074896032 VenueClient     VenueClient.py:802 DEBUG
> EnterVenue; url=https://vv2.mcs.anl.gov:9000/Venues/default
> > > > 18/08/04 16:14:18 1074896032 CertificateManager
> CertificateManager.py:633 DEBUG HaveValidProxy: found proxy ident /O=Access
> Varakliotis2/CN=proxy
> > > > 18/08/04 16:14:18 1074896032 VenueClient     VenueClient.py:825 INFO
> EnterVenue: Error getting node capabilities
> > > > 18/08/04 16:14:18 1074896032 VenueClient     VenueClient.py:700 DEBUG
> EnterVenue: Invoke venue enter
> > > > 18/08/04 16:14:18 1074896032 VenueClient     VenueClient.py:667 ERROR
> SOAP fault occurred
> > > > Traceback (most recent call last):
> > > >   File "/usr/local/lib/python2.3/site-packages/SOAPpy/Client.py", line
> 347, in __call
> > > >     config = self.config)
> 187, in call
> > > >     r.endheaders()
> > > >   File "/usr/local/lib/python2.3/httplib.py", line 712, in endheaders
> > > >     self._send_output()
> > > >   File "/usr/local/lib/python2.3/httplib.py", line 597, in
> _send_output
> > > >     self.send(msg)
> > > >   File "/usr/local/lib/python2.3/httplib.py", line 564, in send
> > > >     self.connect()
> > > >   File "/usr/local/lib/python2.3/site-packages/pyGlobus/io.py", line
> 1425, in connect
> > > >     self.sock.connect(self.host, self.port, self.io_attr)
> 988, in connect
> > > >     raise ex
> > > > 18/08/04 16:14:18 1074896032 VenueClient     VenueClient.py:846 ERROR
> EnterVenue: globus tcp exception: ('globus_xio_gsi: gss_init_sec_context
> failed.',)
> > > > 18/08/04 16:14:18 1074896032 VenueClient     VenueClient.py:853 ERROR
> EnterVenue: failed
> > > >   File "/home/ucacsva/agtk-cvs/AccessGrid/AccessGrid/VenueClient.py",
> line 829, in EnterVenue
> > > >     self.__EnterVenue(URL)
> line 701, in __EnterVenue
> > > >     (venueState, self.privateId, self.streamDescList ) =
> self.__venueProxy.Enter( self.profile )
> > > >   File "/home/ucacsva/agtk-cvs/AccessGrid/AccessGrid/Venue.py", line
> 3339, in Enter
> > > >     (r1, r2, r3) = self.proxy.Enter(profile)
> 453, in __call__
> > > >     return self.__r_call(*args, **kw)
> 475, in __r_call
> > > >     self.__hd, self.__ma)
> 347, in __call
> 187, in call
> > > >     r.endheaders()
> > > >     self._send_output()
> _send_output
> > > >     self.send(msg)
> > > >     self.connect()
> 1425, in connect
> 988, in connect
> > > >     raise ex
> > > > 18/08/04 16:14:18 1074896032 VenueClient     VenueClientUI.py:2054
> DEBUG bin.VenueClient::EnterVenue: Enter venue with url:
> > > > 18/08/04 16:14:18 1074896032 VenueClient     VenueClientUI.py:2067
> DEBUG warningString:
> > > > 18/08/04 16:14:28 1074896032 VenueClient     VenueClientUI.py:1701
> INFO  --------- END VenueClient
> > > > 18/08/04 16:14:28 1142135600 DataStore     DataStore.py:1530 DEBUG
> Worker 0 gets cmd quit
> > > > 18/08/04 16:14:28 1142135600 DataStore     DataStore.py:1543 DEBUG
> Worker 0 exiting
> > > > 18/08/04 16:14:28 1150528304 DataStore     DataStore.py:1603 ERROR
> Exception handling request
> > > >   File "/home/ucacsva/agtk-cvs/AccessGrid/AccessGrid/DataStore.py",
> line 1599, in thread_run
> > > >     self.handle_request()
> > > >   File "/usr/local/lib/python2.3/SocketServer.py", line 217, in
> handle_request
> > > >     request, client_address = self.get_request()
> 843, in get_request
> > > >     raise(str(self.socket) + str(" is having trouble listening!:" +
> str(ex.args)))
> > > > <pyGlobus.io.GSITCPSocket instance at 0x41de94ec> is having trouble
> listening!:('an I/O operation was cancelled',)
> > > > 18/08/04 16:14:28 1133742896 Hosting     Server.py:65 ERROR Exception
> in SOAP server main loop
> > > >   File
> "/home/ucacsva/agtk-cvs/AccessGrid/AccessGrid/hosting/SOAPpy/Server.py",
> line 63, in Run
> > > >     self._server.handle_request()
> handle_request
> > > >   File "/usr/local/lib/python2.3/site-packages/SOAPpy/GSIServer.py",
> line 140, in get_request
> > > >     sock, addr = ThreadingGSITCPSocketServer.get_request(self)
> 843, in get_request
> str(ex.args)))
> > > > <pyGlobus.io.GSITCPSocket instance at 0x41de908c> is having trouble
