{SPAM?} Re: [AG-TECH] CVS AGTk client cannot connect to default          server (RH9.0)
    Socrates Varakliotis
    S.VarakliotiS at cs.ucl.ac.uk
    Fri Aug 20 15:04:24 CDT 2004
Aha!
All problems fixed now. VenueClient seems to be running fine so far.
Thanks for the support guys.
Socrates.
----- Original Message -----
To: "Socrates Varakliotis" <S.Varakliotis at cs.ucl.ac.uk>
Cc: "ag-tech" <ag-tech at mcs.anl.gov>
Sent: Friday, August 20, 2004 7:14 PM
Subject: {SPAM?} Re: [AG-TECH] CVS AGTk client cannot connect to default
server (RH9.0)
> Socrates:
> That file is created during the last step of the source install process:
> % source $GLOBUS_LOCATION/etc/globus-user-env.csh
> % $GPT_LOCATION/sbin/gpt-postinstall
> Have you done this step, and you still don't have the file?
> Tom
> Socrates Varakliotis wrote:
> > Thomas' comment regarding the LANG env variable took me a step further.
> > gpt installed fine after unsetting it on RH9.
> > Then, the Globus toolkit v.2.4.3 got installed fine.
> > The next step was to re-install pyGlobus (swig has been installed
> > already). Now, here's another problem:
> > [root at Gorilla pyGlobus]# python2.3 setup.py install --run-swig
> > Checking for which modules to build
> > Checking the util module
> > Missing dependency to build the util package.
> > This package is required to build all of pyGlobus.
> > The following is the error message from globus-makefile-header.
> > ('ERROR: Cannot open
> > /usr/local/globus/libexec/globus-sh-tools-vars.sh!\n',)
> > Now exiting from the build.
> > Looking inside /usr/local/globus/libexec I can't find the file
> > globus-sh-tools-vars.sh, which is required by the installer script. Here
> > is what exists in this directory:
> > globus-args-parser-header
> > globus-bootstrap.sh
> > globus-build-env-gcc32dbgpthr.sh
> > globus-is-local-user
> > globus-libc-hostname
> > globus-sh-tools.sh
> > gpt-bootstrap.sh
> > Any more comments? Is this a version problem again?
> > Socrates.
> >>> The paragraph on Linux says:
> >>> 1. Have Globus 2.4.3 installed, instructions for that are elsewhere.
> >>> (you only *need* the globus-data-management-client bundle)
> >>> Where exactly are the instructions you mention? And where is globus
> >>> 2.4.3?
> >>> AFAIK, the latest stable globus release is 3.2.1.
> >> I finally managed to locate globus 2.4.3 under globus' download
> >> archives (a well-hidden link):
http://www.globus.org/gt2.4/download.html
> >> Now, I have the following problem: The gpt-3.0.1 won't install,
> >> dumping the following error:
> >> [ucacsva at Gorilla gpt-3.0.1]$ ./build_gpt --prefix=$GPT_LOCATION
> >> build_gpt ====> installing GPT into /usr/local/globus
> >> build_gpt ====> building support/Compress-Zlib-1.16
> >> build_gpt ====> building support/Archive-Tar-0.22
> >> build_gpt ====> building support/PodParser-1.18
> >> build_gpt ====> building support/Digest-MD5-2.20
> >> Makefile:75: *** missing separator.  Stop.
> >> ERROR: the following command failed: make >/dev/null
> >> Any ideas please?
> >> Regards,
> >> Socrates.
