[AG-TECH] AG2.2 - Venue Client
    Monika Rabarison
    monika.k.rabarison at ccaix.jsums.edu
    Thu Aug 12 08:41:29 CDT 2004
Anne,
I just installed 2.3 on XP yesterday, without any problem.
I am wondering if you got a certificate or not.
Monika
On Wed, 11 Aug 2004, Anne M. Hammond wrote:
> I just installed AGTk2.3 on a brand new WinXP laptop with no previous
> AGTk installation.  I installed the required Active Python and
> wxPython first.
> I am having the same issues as with 2.2.  Does not bring up RAT
> or Vic.  Menu Preferences / Manage My Node
>     brings up the "Set Node Service URL"
>     OK brings up Node Management Error (cannot open node management)
>     Cancel does nothing.
> Both Audio and Video are enabled in the menu.
> Is this a security/permissions issue, rather than incompatibility
> between versions??
> TIA.
> >>- Start the VenueClient
> >>- Select Preferences->ManageMyNode
> >>      OK produces the error listed below
> >>      Cancel brings up nothing.
> >>- Add the service manager at localhost 11000
> >>- Add services (audio, videoconsumer, videoproducer) to the service manager
> >>- Save the node config as the default
> >>>From Windows Menu:
> >>Venue Client
> >>Access Grid Toolkit 2.2
> >>  Configure
> >>    Node Management
> >>    Add ServiceManager  (add localhost port 11000)
> >>    Window:  Message
> >>             Service Manager is unreachable
> >>(https://jil-188-dhcp17.Colorado.EDU:11000/ServiceManager)
> >>    Then it will bring up the menu to Add the services.  It I click on
> >>    a service/OK, it doesn't add it to the ServiceName list.
> >>>Date: Wed, 11 Aug 2004 14:21:07 -0500
> >>>From: Thomas Uram <turam at mcs.anl.gov>
> >>>User-Agent: Mozilla Thunderbird 0.7.3 (Windows/20040803)
> >>>X-Accept-Language: en-us, en
> >>>MIME-Version: 1.0
> >>>To: "Anne M. Hammond" <hammond at solarz.Colorado.EDU>
> >>>Subject: Re: [AG-TECH] AG2.2 - Venue Client
> >>>Content-Transfer-Encoding: 7bit
> >>>X-Spam-Checker-Version: SpamAssassin 2.63 (2004-01-11) on lcd.colorado.edu
> >>>X-Spam-Level: *
> >>>X-Spam-Status: No, hits=1.9 required=5.0 tests=WEIRD_PORT autolearn=no
> >>version=2.63
> >>>You should not set the node service url.  Just select ManageMyNode and
> >>>then do the steps I listed earlier.  Let me know if you run into problems.
> >>>Tom
> >>>>Yes.  I start the Venue Client from the Windows menu.
> >>>>Then set Service Node URL by clicking OK.
> >>>>The next thing that comes up is a window:
> >>>>Can not open node management
> >>>>at https://jil-188-dhcp17.Colorado.EDU:11000/NodeService
> >>>>>Date: Wed, 11 Aug 2004 14:01:51 -0500
> >>>>>MIME-Version: 1.0
> >>>>>X-Spam-Level: *
> >>>>version=2.63
> >>>>>How did you start the venue client?  From the menu?
> manager
> >>>>>>I started this.  But there is an error message after Step 3.
> >>>>>>Actually it is not localhost but
> >>>>>>Set node service URL
> >>>>>>Please, specify node service URL
> >>>>>>Address: https://jil-188-dhcp17.Colorado.EDU:11000/NodeService
> >>>>>>Click OK
> >>>>>>then pop up
> >>>>>>at https://jil-188-dhcp17.Colorado.EDU:1100/NodeService
> >>>>>>>Date: Wed, 11 Aug 2004 13:26:12 -0500
> >>>>>>>MIME-Version: 1.0
> lcd.colorado.edu
> >>>>>>>X-Spam-Level:
> >>>>>>>X-Spam-Status: No, hits=0.0 required=5.0 tests=none autolearn=no
> >>version=2.63
> >>>>>>>Did you go through the steps I mentioned?  You shouldn't have to
> >>>>>>>reinstall to recover from this problem, just build a new node
> >>configuration.
> >>>>>>>Michael Braitmaier's suggestion is not suitable for the way you're
> >>>>>>>running the software, so you should ignore that advice.
> >>>>>>>Tom
> >>>>>>>>I submitted a bug.
> >>>>>>>>I also tried creating a zero length defaultWindows file.  The
> >>>>>>>>debug output is in the bug submission.
> >>>>>>>>What about uninstalling 2.2, mving c:\. . .\Application Data\AccessGrid
> >>>>>>>>aside and just reinstalling 2.2, then mv'ing the certificates back.
> >>>>>>>>Anne
> >>>>>>>>>Date: Wed, 11 Aug 2004 12:29:12 -0500
> >>>>>>>>>MIME-Version: 1.0
> >>lcd.colorado.edu
> >>>>>>>>>X-Spam-Level:
> >>>>version=2.63
> >>>>>>>>>Yes, that's probably a good idea.  If you're sending large logfiles or
> >>>>>>>>>such, you can send them to me separately, or put them on the web
> >>>>>>>>>somewhere and send the link.
> >>>>>>>>>Tom
> >>>>>>>>>>Thanks Tom.  Should I cc the list on any correspondence?
> >>>>>>>>>>Anne Hammond
> >>>>>>>>>>U of Colorado at Boulder
> >>>>>>>>>>>Date: Wed, 11 Aug 2004 08:48:29 -0500
> >>>>>>>>>>>MIME-Version: 1.0
> >>>>>>>>>>>CC: ag-tech at mcs.anl.gov
> >>>>lcd.colorado.edu
> >>>>>>>>>>>X-Spam-Level:
> >>>>>>version=2.63
> >>>>>>>>>>>X-Keywords:
> >>>>>>>>>>>Hi Anne:
> >>>>>>>>>>>The error you identified shouldn't prevent the node setup wizard from
> >>>>>>>>>>>starting.  There should be another indication of problem in that
> >>>>>>>>>>>logfile; if you don't see it, you should file a bug for the node
> setup
> >>>>>>>>>>>wizard in our bugzilla (http://bugzilla.mcs.anl.gov/AccessGrid) and
> >>>>>>>>>>>include the logfile.
> >>>>>>>>>>>The problem you encountered with rat and vic not starting is due to a
> >>>>>>>>>>>difference in the personal node setup between 2.1 and 2.2.  You
> should
> >>>>>>>>>>>be able to get the media tools working by building a new node
> >>>>>>configuration:
> >>>>manager
> >>>>>>>>>>>It should then work each time you start the venue client.
> >>>>>>>>>>>Tom
> >>>>>>>>>>>>I had installed AG2.2, after installing ActiveState Active Python
> 2.3
> >>>>>>>>>>>>and wxPython 2.4 for Python 2.3.
> >>>>>>>>>>>>I am using an IBM ThinkPad with a Logitech camera (which works).
> >>>>>>>>>>>>When I bring up the Venue Client, the Rat and Vic thumbnails do not
> >>>>>>>>>>>>come up.  Audio and Video are enabled.
> >>>>>>>>>>>>I tried twice to start the Node Setup Wizard.  It gets 80% into
> >>>>>>>>>>>>the green startup bar, and then gives a messages that it cannot
> >>>>>>>>>>>>start the Wizard.
> >>>>>>>>>>>>I have run the Venue Client in debug mode.  The first ERROR is
> >>>>>>>>>>>>venueclient.py:317 ERROR Error loading default configuration.
> >>>>>>>>>>>>Is there a way to troubleshoot this, or do I need to fall back to
> >>>>>>>>>>>>AG2.1?  If I need to fall back, do I need to get the older versions
> >>>>>>>>>>>>of Active Python and wxPython??
> >>>>>>>>>>>>Thanks in advance.
> >>>>>>>>>>>>Anne Hammond
> >>>>>>>>>>>>University of Colorado at Boulder
Monika Rabarison
Systems Administrator
Information Technology/HPCVI
Jackson State University
Office:(601)979-5933
SciVis Lab:(601)979-1061
JSUvisNode:(601)979-1056
JSUeNode:(601)979-1081
