[AG-TECH] AG2.2 - Venue Client
    Anne M. Hammond
    hammond at solarz.Colorado.EDU
    Wed Aug 11 19:22:09 CDT 2004
I just installed AGTk2.3 on a brand new WinXP laptop with no previous
AGTk installation.  I installed the required Active Python and
wxPython first.
I am having the same issues as with 2.2.  Does not bring up RAT
or Vic.  Menu Preferences / Manage My Node
    brings up the "Set Node Service URL"
    OK brings up Node Management Error (cannot open node management)
    Cancel does nothing.
Both Audio and Video are enabled in the menu.
Is this a security/permissions issue, rather than incompatibility
between versions??
TIA.
>Anne M. Hammond wrote:
>>- Start the VenueClient
>>- Select Preferences->ManageMyNode
>>      OK produces the error listed below
>>      Cancel brings up nothing.
>>- Add the service manager at localhost 11000
>>- Add services (audio, videoconsumer, videoproducer) to the service manager
>>- Save the node config as the default
>>>From Windows Menu:
>>Venue Client
>>Access Grid Toolkit 2.2
>>  Configure
>>    Node Management
>>    Add ServiceManager  (add localhost port 11000)
>>    Window:  Message
>>             Service Manager is unreachable
>>(https://jil-188-dhcp17.Colorado.EDU:11000/ServiceManager)
>>    Then it will bring up the menu to Add the services.  It I click on
>>    a service/OK, it doesn't add it to the ServiceName list.
>>>Date: Wed, 11 Aug 2004 14:21:07 -0500
>>>From: Thomas Uram <turam at mcs.anl.gov>
>>>User-Agent: Mozilla Thunderbird 0.7.3 (Windows/20040803)
>>>X-Accept-Language: en-us, en
>>>MIME-Version: 1.0
>>>To: "Anne M. Hammond" <hammond at solarz.Colorado.EDU>
>>>Subject: Re: [AG-TECH] AG2.2 - Venue Client
>>>Content-Transfer-Encoding: 7bit
>>>X-Spam-Checker-Version: SpamAssassin 2.63 (2004-01-11) on lcd.colorado.edu
>>>X-Spam-Level: *
>>>X-Spam-Status: No, hits=1.9 required=5.0 tests=WEIRD_PORT autolearn=no
>>version=2.63
>>>You should not set the node service url.  Just select ManageMyNode and
>>>then do the steps I listed earlier.  Let me know if you run into problems.
>>>Tom
>>>>Yes.  I start the Venue Client from the Windows menu.
>>>>Then set Service Node URL by clicking OK.
>>>>The next thing that comes up is a window:
>>>>Can not open node management
>>>>at https://jil-188-dhcp17.Colorado.EDU:11000/NodeService
>>>>>Date: Wed, 11 Aug 2004 14:01:51 -0500
>>>>>MIME-Version: 1.0
>>>>>X-Spam-Level: *
>>>>version=2.63
>>>>>How did you start the venue client?  From the menu?
manager
>>>>>>I started this.  But there is an error message after Step 3.
>>>>>>Actually it is not localhost but
>>>>>>Set node service URL
>>>>>>Please, specify node service URL
>>>>>>Address: https://jil-188-dhcp17.Colorado.EDU:11000/NodeService
>>>>>>Click OK
>>>>>>then pop up
>>>>>>at https://jil-188-dhcp17.Colorado.EDU:1100/NodeService
>>>>>>>Date: Wed, 11 Aug 2004 13:26:12 -0500
>>>>>>>MIME-Version: 1.0
lcd.colorado.edu
>>>>>>>X-Spam-Level:
>>>>>>>X-Spam-Status: No, hits=0.0 required=5.0 tests=none autolearn=no
>>version=2.63
>>>>>>>Did you go through the steps I mentioned?  You shouldn't have to
>>>>>>>reinstall to recover from this problem, just build a new node
>>configuration.
>>>>>>>Michael Braitmaier's suggestion is not suitable for the way you're
>>>>>>>running the software, so you should ignore that advice.
>>>>>>>Tom
>>>>>>>>I submitted a bug.
>>>>>>>>I also tried creating a zero length defaultWindows file.  The
>>>>>>>>debug output is in the bug submission.
>>>>>>>>What about uninstalling 2.2, mving c:\. . .\Application Data\AccessGrid
>>>>>>>>aside and just reinstalling 2.2, then mv'ing the certificates back.
>>>>>>>>Anne
>>>>>>>>>Date: Wed, 11 Aug 2004 12:29:12 -0500
>>>>>>>>>MIME-Version: 1.0
>>lcd.colorado.edu
>>>>>>>>>X-Spam-Level:
>>>>version=2.63
>>>>>>>>>Yes, that's probably a good idea.  If you're sending large logfiles or
>>>>>>>>>such, you can send them to me separately, or put them on the web
>>>>>>>>>somewhere and send the link.
>>>>>>>>>Tom
>>>>>>>>>>Thanks Tom.  Should I cc the list on any correspondence?
>>>>>>>>>>Anne Hammond
>>>>>>>>>>U of Colorado at Boulder
>>>>>>>>>>>Date: Wed, 11 Aug 2004 08:48:29 -0500
>>>>>>>>>>>MIME-Version: 1.0
>>>>>>>>>>>CC: ag-tech at mcs.anl.gov
>>>>lcd.colorado.edu
>>>>>>>>>>>X-Spam-Level:
>>>>>>version=2.63
>>>>>>>>>>>X-Keywords:
>>>>>>>>>>>Hi Anne:
>>>>>>>>>>>The error you identified shouldn't prevent the node setup wizard from
>>>>>>>>>>>starting.  There should be another indication of problem in that
>>>>>>>>>>>logfile; if you don't see it, you should file a bug for the node
setup
>>>>>>>>>>>wizard in our bugzilla (http://bugzilla.mcs.anl.gov/AccessGrid) and
>>>>>>>>>>>include the logfile.
>>>>>>>>>>>The problem you encountered with rat and vic not starting is due to a
>>>>>>>>>>>difference in the personal node setup between 2.1 and 2.2.  You
should
>>>>>>>>>>>be able to get the media tools working by building a new node
>>>>>>configuration:
>>>>manager
>>>>>>>>>>>It should then work each time you start the venue client.
>>>>>>>>>>>Tom
>>>>>>>>>>>>I had installed AG2.2, after installing ActiveState Active Python
2.3
>>>>>>>>>>>>and wxPython 2.4 for Python 2.3.
>>>>>>>>>>>>I am using an IBM ThinkPad with a Logitech camera (which works).
>>>>>>>>>>>>When I bring up the Venue Client, the Rat and Vic thumbnails do not
>>>>>>>>>>>>come up.  Audio and Video are enabled.
>>>>>>>>>>>>I tried twice to start the Node Setup Wizard.  It gets 80% into
>>>>>>>>>>>>the green startup bar, and then gives a messages that it cannot
>>>>>>>>>>>>start the Wizard.
>>>>>>>>>>>>I have run the Venue Client in debug mode.  The first ERROR is
>>>>>>>>>>>>venueclient.py:317 ERROR Error loading default configuration.
>>>>>>>>>>>>Is there a way to troubleshoot this, or do I need to fall back to
>>>>>>>>>>>>AG2.1?  If I need to fall back, do I need to get the older versions
>>>>>>>>>>>>of Active Python and wxPython??
>>>>>>>>>>>>Thanks in advance.
>>>>>>>>>>>>Anne Hammond
>>>>>>>>>>>>University of Colorado at Boulder
