[AG-TECH] bootable live cd iso avalaible to download [CMM #1690]
    Bob Riddle
    bdr at internet2.edu
    Tue Aug 10 07:34:53 CDT 2004
well ... it sort of works ... except that RAT doesn't appear at all &
vic doesn't appear to "send" video.  I did thru the files and found vic
& rat & started them by hand ...
BTW -  this is normally a WinXP machine that I run an AG- PIG on.  A
great idea that seems close - if we send in all our "what I did to get
it to work on my system" to you will that end up in the distribution or
on a web-page somewhere?
Joseph wrote:
> Hi
> I'm pleased to see AG on a knoppix might help you. However, I just
> would  like to warn you about a possible trouble : this bootable live
> cd *should*  be working with all pc, but it's not 100% sure. It may be
> necessary to  test it before on each kind of pc and sometimes may
> required some tricks  (mainly based on the use of cheatcodes
> generally, which is quite easy, but  still...).
> Apart from this, the access of people with Anonymous certificate is
> just a  question of configuration of the AG Node server. In your case
> Chris seems  to agree to change it, so it shouldn't be a trouble anymore.
> Cheers,
>     Joseph
> On Tue, 10 Aug 2004 16:11:56 +1000, Christoph Willing
> <willing at itee.uq.edu.au> wrote:
>> On Tue, 2004-08-10 at 15:40, Duncan Waddell wrote:
>>> However the Certificate provided with the Knoppix CD does not allow me
>>> to connect to the Asia-Pacific Access Grid Venue Server.  If I
>>> import my
>>> own certificate from floppy disk I can enter happily enough but I am
>>> now
>>> thinking of 40 schools and should they use the existing CD I would have
>>> to relay CyberSTEM via a non-local venue server.  (i.e. they could only
>>> currently see us if we served via the USA ANL venue server)
>> Duncan,
>> This is an issue with the APAG server not accepting anonymous
>> certificates. I'm working on fixing this, sooner rather than later.
>> chris
Bob Riddle (bdr at internet2.edu)    Technologist,Internet2
3025 Boardwalk, Suite 100         Ann Arbor, Michigan  48108
Business Phone: 734.913.4257      Fax Number:  734.913.4255
"Math illiteracy affects 7 out of every 5 people"
